0032,0039,0036.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Check these codes: 0128 0013 0002 0071 0380
Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Hello
Codes for Panasonic with Chunghop RM series remote control are:
0001/0003/0019/0037/0040/0106/0110/0111/0112/0114/0190/0212/0241/0711/0745/1036
If you are in need for a three digit code; remove the first Zero from each code and take the rest three digits.
Eg: for 0001 [four digit code] (001) is its three digit code. OK.
