You must convert the Monogram Wizard file to a format that your XL 6000 can read. If you have the Singer Sew Ware Conversion Tool, you can do this by opening the conversion software and simply saving the file as an (note: Fixya thinks the "dot triple x" file format is profanity, but it's the main file format used for the XL-6000 so I had to type it out this way) or a .sew format. Once the file is in the correct format, you can then import it to the XL 6000. To import, you must have a special cable (serial port to USB) that has an FTDI chip in it. Only serial port to USB cables with the FTDI chip will work. Here is a link where you can purchase said cable:
http://www.cablesalesusa.com/index.php?main_page=product_info&cPath=472&products_id=1968
After using the cable with FTDI chip to connect your computer to your XL 6000, you must then ensure the com port settings match. I am including below some links that may be helpful to you in figuring all this out. These documents were helpful to me when I was trying to figure out all this stuff for my XL 6000, and I hope they will also be helpful to you. Blessings to you and yours.
How to change the COM port for USB Serial adapter on Windows 7
How to configure the Singer Approved USB Adapter with Windows 7
I also have additional helpful files, but this site will not allow me to upload a file in .pdf format. If you would like to provide your email address, I would be happy to email the documents to you. One is a workbook for the XL 6000 (much more detailed than the Owner's Manual).
Here are two additional pages that might be helpful:
Cannot send a pattern from the computer to the sewing machine. I get a cannot transfer data statement.
