Tip & How-To about Computers & Internet
As a universal file format out there, PDF is considered ideal for
uploading, downloading, and publishing documents over the internet. But
as it is no easy to edit or change the text in PDF format, sometimes you
may need to convert PDF to other format file if you make some changes
to your PDF files?
Recently I find many people wonder how to convert PDF to word,
but not willing to pay for Adobe Acrobat. So, here is the question, how
to convert PDF to Word without Adobe Acrobat? With respect to this
problem, I believe you can find many free online PDF converters. It's a
really good option if your PDF files are not important. However if you
want to convert some confidential PDF files to Word, it isn't an ideal
choice without doubt.
In that situation, my suggestion is to get an efficient PDF to Word
converter. Aside from 100% free online PDF convert websites, there're
many programs allowing you to convert PDF to Word for free. Here I will
introduce a free PDF to Word convert software and teach you how to
covert PDF to Word by using this program.
Nemo PDF To Word is completely free Word to PDF convert software. By
using it, you can convert your PDF files to well-formatted and editable
Word/RTF in seconds. After conversion, the original text, images,
tables, columns, graphics and other formats are well saved in the
generated files. It supports batch conversion and partial conversion,
greatly saving your time.
As for how to convert PDF to word by using free Nemo PDF to Word, just follow the steps below, you can know how to convert PDF to Word for free.
Step 1. Import PDF flies
Click Add Files button to load your target PDF files into the program.
The file information like file size and pages will be listed once
imported.
Step 2. Make settings
Under Output, you can specify the page range, select Word documents as output file format and output path.
Step 3. Covert PDF files to Word
Click the Convert button to start converting your PDF files to Word.
When the conversion completes, a dialog box will pop up. You can view
the generated Word files directly by clicking Open File or Open Folder
on it.
Worth Noting:
1. During conversion, the Convert button will be changed to Stop button.
You can stop converting anytime by clicking the Stop button.
2. If your PDF files are encrypted, it will pop up a dialog box for
password immediately after importing it. You can load and convert the
secured file normally after inputting the correct password.
3. If you want to convert the generated Word documents to PDF, Nemo PDF Converter will do you a favor.
