Go to 'start -> Devices and Printers' and click 'Add a device' from top of the window.
Now your Windows 7 system will search the bluetooth device which connected to your system.
Click the bluetooth device you want to install from the list and
then click the 'Next' button and wait for windows to configure the
bluetooth device. If prompted to enter a passcode, enter the default
code listed in the bluetooth device manual. In many cases, the default
passcode will be '0000'.
Now the bluetooth device has successfully installed and ready to use.
Note: If you bluetooth device was not listed in the search results from
Step 4, make the device discoverable. Access your Bluetooth-enabled
device's settings page, and turn on the device's 'Listen' or
'Discoverable' function to allow you computer to find it.
I hope it will help you. :-))
Feel free to get technical assistance at http://www.vtechsquad.com/dell-support/ if you get any issue with your Dell Latitude notepad/laptop/desktop.
1.Go to Start then control panel, double click on bluetooth
2.Then Click Settings and then check the box beside the "Turn Discovery On" Apply and OK.
>>>>"M.J Trusedell"
SOURCE: blue tooth
just go to control panel and enable bluetooth in your pc ...if problem continues there may be some virus in your pc blocking the bluetooth connectivity check and remove it
