Computers & Internet Logo
Posted on Aug 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Rakesh Warrier
Level 3:
  • Master 708 Answers
  • Posted on Aug 18, 2011
Rakesh Warrier
Master
Level 3:
Answers
708
Questions
0
Helped
209572
Points
1609
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Changing nat type
Try directly wiring your PS3 to your internet source. It is also possable, it could be your friend's connection.
I can't change the nat type for ps3 or call of duty black ops how do i change the nat type
When you do a connection test on your PS3, what NAT type shows up; 1, 2, or 3. If you're worried about the STRICT NAT type in Black Ops, don't worry about it, the problem is the game and not your router.
http://forums.dlink.com/index.php?action=printpage;topic=21218.0
2answers
I have an actiontec modem connected to my ps3. When I play call of duty my Nat is moderate. How can I get my Nat set as open?
you should try to get your nat type to say not availible and look on youtube for help
type in help with getting nat type to not availible on ps3
1helpful
How do i change my nat type
go on a computer.
1. in the internet address bar type in 192.168.1.1 or routerlogin.net
2. enter admin and password in the fields
3. your now in your routers setup
4. find a setting called nat
5. set it to open instead of secure
this changes your nat type to 2
if that doesnt work
1. login to router as usual, but find a setting called default dmz server
2. enter the IP address of your PS3 as the dmz server (to see what your ps3's ip is go to network > connection settings and have a look.
this should definitley make it a nat 2 - but try the first method
Cant get nat type 2 on my ps3 i have a dlink wireless n dual band
on the ps3 you will need to do a port fowarding in the router interface and pretty much the same in the other questions
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Nat 3
access ur interface of the modem
go to ur command prompt and type
ipconfig | get the defaultgareway | enter that in address bar
username and password should be admin | go to advanced | pinhole
thats how u set up the nat
rate me please !
JULY
Ps3 call of duty 4&5 can`t connect with friends
its the dns servers 1 and 2 try changeing them. that worked for me otherwise buy a dlink routere nat type 2 No PROB !
2answers
Cant to get a friend to join online playing Smackdown vs Raw 2008
There is usually two reasons for this.
The first one is the game is just having server problems.
The second one is usually the problem and that has to do with your router settings causing you to have a 'NAT Type 3' connection which can cause connection issues with other players.
Having a closed or limited NAT on your gaming console will cause a variety of issues. Similar to strict, moderate or open on an Xbox 360, the PS3 offers Type 3, Type 2 and Type 1 NAT results. These break down as follows:
Type 1 - Connected directly to the internet (no router/firewall). Should have no issues.Type 2 - Connected through a router properly. Should have no issues.Type 3 - Connected through a router without open ports or DMZ setup for PS3. Everything should function properly, but you may have connection, voice chat or other issues.While most everything will function properly regardless of what your NAT setting is, your best bet is to set up your PS3 so that you can obtain a Type 1 or Type 2 NAT. Since most of us have routers at home for connecting multiple computers or devices to the internet, chances are the best we will get will be Type 2. Thankfully that's fine and everything will work properly.
If you have not adjusted your settings on your PS3 or router, chances are you have a Type 3 NAT and probably never knew it. With a few simple changes you too can have a Type 2 NAT. Order now for just $19.99. But wait, there's more. joker.gif
The first thing you will want to do is check your network connection. Head on over to the Network Settings tab on the XMB. It looks like this:
Once there choose the Internet Connection Test item. It looks like this:
You will receive a warning letting you know that you will be signed out in order to perform the test. Choose okay. If you have not made any setting changes in your PS3 or Router, chances are you will receive the following message:
The warning reads: "When the NAT type is type 3, chat or the communication features of games may be restricted. For more information, refer to the online instruction manual."
If you run the test and have Type 2 or Type 1, stop fooling around and go play some games! If, however, you have Type 3, read on for help on opening up your NAT.
In order to open up your NAT on your PS3 you will need to make an adjustment on your PS3 and on your router. First you will want to set up your PS3 for a static IP address. This means turning off DHCP and assigning your PS3 a single, static IP address. Before you start this process head over to the network tab on the XMB and choose "Internet Connection Status." From here note your current IP address, your subnet mask, your default router and primary and secondary DNS settings. Write these down, you will need them in the following steps.
To do this, visit the Internet Connection Settings tab on the XMB. It looks like this:
From here most of the settings can simply be passed through with default settings. There are two areas, however, that you have to change. The first is choosing a Custom address setting (instead of Easy).
From here, you will want to choose Manual IP Address Setting:
Remember the settings you wrote down from your status page? You will need them here. You will have to enter in the static IP Address you want to assign to your PS3, the Subnet Mask (which is usually 255.255.255.0), the default router (the IP address of your router, most often 192.168.1.1 or 192.168.100.1), and the Primary and Secondary DNS settings. You will have to input all of these numbers. This is made much easier with a DVD Remote or keyboard.
Please NOTE - You will want to set the last number of your IP address high enough that other wireless or wired items on your network will not be assigned the same number through DHCP. While DHCP had chosen .3 as an IP address for my PS3 initially, I bumped it up to .23 because I have less than 23 items in my network. If you do not have DHCP enabled on your router, you do not need to worry about this and can simply choose an IP address that does not conflict with your other devices and which is available through your router.
Once you have all of the settings input, press X to save them. Your settings will change and the PS3 will offer to perform an Internet Connection Test for you. If you let it do the test now chances are you will still get a Type 3 NAT connection. Don't fret little bear, we still have one more step.
In addition to making the necessary changes on your PS3, you will also have to open up some ports on your router. The ports you need to open are:
TCP: 80, 443, 5223
I have a Linksys Router and my port forward settings page looks like this:
Depending on what type of router you have, your settings page may look different. In order to obtain an open or Type 2 NAT, you will need to open those ports listed above.
You can see in my screen capture that my PS3 is listed with its static IP address that I set above (.23) and that all of the necessary ports are forwarded to that IP address. The X listed items above (.24) are for my Xbox 360 so you don't have to worry about those.
Once you have forwarded these ports and saved your settings its a good idea to unplug and plug back in your router. This will refresh everything on your network connected to your router. Once done head back to your PS3 and perform an Internet Connection Test. If you did everything correctly you should receive the following page:
Congratulations, your NAT is now setup and working properly!
Nat is too strict (Nat Type 3) and You have been disconected to..
should be the interference that is killing your network....
Try to remake all your PS3 wireless connections
try to use more powerfull DBI wireless Antennas..
PS3 NAT type problem using Zyxel P-660R-D1 series DSL Modem
thanks for help , the error was from user that have viruse on his pc , thanks again
Grand Canyon Tech
Grand Canyon Tech
