SOURCE: Epson rx420 printer
Another post suggests that you printer is dead -see (http://www.fixya.com/support/t354202-epsom_rx_425_just_prints_half_page) but I've had the same problem - things seem to be ok after I reset to the defaults in the main page of the printing preferences.
SOURCE: Hp 2300dtn Poor quality printing
Well lets start with DISREGARD ALL THE ABOVE BULL in the above brainless clarification request first noted. Here's a little good advice for you from a 14 year veteran printer tech.
Lets start with the cheapest and easiest moving to the more difficult or more expensive. Your problem can be caused by a few differnt things.
Print a configuration page (on the printer menu press check button, scroll to info menu, press check, scroll to print configuration, press check. Once you have the look for the page count on the page.
Try fresh good paper from a sealed ****. If your paper has picked up moisture this will show up as light or uneven print.
Next if the printer is over 100K page count, replace the transfer roller (foam roller inside printer under the toner cartridge). Lets try cleaning it first if your under 100K or to see if it improves at all. Any improvement will verify the transfer roller as bad. Review the photo below as it shows the transfer roller end inside the printer. The screwdriver is showing where the release white clips are (two). Press the tabs and lift the left side. The right will come out of the hole socket on its own but note where the hole on the right is for replacement. Try not handling the roller with your bare hands any more than you must as oil from your hands can cause slight imaging defects if your hands are sweaty or damp.
Using a clean rag (like t-shirt material) dampened (not soaking) with 99% alcohol (not 70%) lets clean the roller. Gently but firmly scrub the talc and paper dust buil-up from the roller. Once you've removed the build up it should return to a dark grey color. Let the 99% alcohol dry (5 minutes or so)and reinstall.
Try printing again. If the problem is solved your done. If not and it has improved, you will need a new transfer roller. They are available on Ebay much cheaper than from a dealer. The part number to search for is RM1-0343. Here's a link to ebay for one at around $20.00 landed.
http://cgi.ebay.com/LJ-2300-Transfer-Roller-New-OEM-RM1-0343-Unopened_W0QQitemZ270247145853QQcmdZViewItem?_trksid=p3286.m20.l1116
If the problem is the same, your problem is more than likely a dirty laser scanner lense. You'll need to remove the covers from the printer to accomplish this. The laser scanner can be located under the top cover. It's the larger black box on the top side of the printer. Once the scanner has been located, remove the top cover. DO NOT TOUCH THE MULTI SIDED SPINNING MIRROR TO THE REAR OF THE SCANNER. You will be cleaning the clear lenses and mirror towards the front. You clean this gently with a CLEAN and DRY Q-tip. Use a few Q-tips rather than re-applying a dirty one. Heck they are cheap!
Re-assemble the printer and try printing again. One of the steps above should resolve your issue. I am enclosing a link to a free service manual for your printer to help you through the disassembly and in the rare case that your issue remains.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%202300%20Service%20Manual.pdf
Hope this helps you a lot more than the first response you receved. If so rate me with a FIXYA!
Thanks.
SOURCE: Picture only prints on one half of page
Try printing a testpage just press print + cancel and make sure you have a paper loaded
SOURCE: Left side of page prints lighter than rest of page
You should contact Dell about returning these for a replacement, it sounds to me like a manufacturer's error.
SOURCE: My CLP-350 Samsung printer only prints black ink
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
