I pulled the weed eater to start it and the pull cord stayed out and won't return back it was working fine early about ten minutes before this happened need help with fixing can work on this myself if i can find out what's going on "need help in St.Catharines".
Hmmmmm. The question is why does it pull hard to begin with? Did the pull cord get wrapped around the pulley in an awkward manner or is the machine seized up? If it's not to difficult, pull the muffler off the machine and look at the piston. If it looks scored (lines up and down the piston through the rings) It's shot and probably not worth fixing. But, If everything looks good, then I'd pull the starter assembly off and see if there's something going on there that's doesn't look right.
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~ i need to know this before i can give you a answer,,
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
When using the weedeater you cant let the line get too shore otherwise it goes back inside the head, you will now have to pull the bump head apart and reload the snipper cord...
The part below the guard is designed to come off for cleaning and restringing, as long as you still have all the parts, you just need to put it back together and it will be fine.
Try a now spark plug first. If it is still hard to start then it is probably because of low compression due to worn rings and these need to be replaced.
