SOURCE: Pentax Optio A10 lcd replacement
I bought my parts from Pentax Imaging Co. for 59.73 + tax + shipping: Part Number 76650-0500 Tel 1 800 877 0155. I am willing to sell this lcd for 55+ ~ ($7 shipping in USA only) because I now have other problems with the camera. LCD is like new condition. (contact: [email protected])
I pulled on the power wires to disconnect the LCD power supply and broke the black one at the connector. I was able to pull the old wire out of the connector and press the remaining section of wire into the connector securely and fix the mistake (use tweasers to prevent this).
As for the LCD information connector strip: Take all of the tape covering this connector off before proceeding because then you will be able to see and use the connector "gate". the gate pivots upward to allows you to place the connector strip in place then you can gently push the gate down to lock the connector strip in place. I tried sliding the connector in and it did not work. Instead it gave me a red screen. I did install my LCD, turned the camera on and it worked, Then...
After dissasembling the camera more that nessesary to be able to insert the menu board's connector strip back into place the camera failed to turn on. I have not found and dissconnected wires and suspect Electrical Shock Discharge for the failure.
If you try this procedure wear a grounding ******** your wrist, or take off the minimum nessessary to preform the work( backplate, sideplate near lense only). You do not need to remove the menu display panel to connect the lcd panel information strip, just remove the tape covering the connector.
SOURCE: pentax optio s6
This is exactly how my problem started. Then after repeated attempts to turn it on or off the lense actually stuck in the on position. After GENTLY forcing it in the off position, it began turning on and would immediately turn back off. After reading every problem posted that had to do with the lense I figured that the lense had somehow worked it's way of the "track or gear" that moves it in and out. I don't recommend this solution unless you figure that the cost of having it repaired proffesionally would be more than to replace the camera (I am a trial and error type of repair person). On my camera, also an S6, when the lense came forward and began to retract, I GENTLY held the lense in place for just a second. I repeated this probably four or five times until it "worked itself" back into the proper position. It does make the clicking noise while doing this which made me a bit nervous but it worked. The camera actually even seems to be focusing better which leads me to believe that possibly it hadn't been quite right for a while. AGAIN... you have to decide if the cost of proffessional repair is worth it to you. I am not a pro but this worked GREAT for me. Hope it helps.
SOURCE: Pentax A10 won't power on
I had almost similar problems with my A10 from day one. The camera shuts down before the battery is depleted, most of the time while I was operating the zoomlens. I bought a new battery, but that didn't solve it. Later I decided to take it apart as a last option. As my suspicion was the zoomlens I took out two crews of the motor that operates it. Now the motor has a bit more space to move. It seemed to be too tight against the gears so it could cause an overload. After that it worked perfectly. I made pictures for hours without having the same fault again. Be carefull to make notes where all the tiny screws belong of the casing. And maybe it will be enough to just loosen the motorscrews, but leaving them out will not make it fall out of it's place. I hope someone can use this information.
Greetings, Ron Timmermans.
SOURCE: what is the maximum size sd card for a Pentax
The A10 accepts SD cards, which max out at 2Gb. The 4Gb card is actually an SDHC (Secure Digital High Capacity) card, not an SD card, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
