Lock the oven door lever to self clean side, and turn it on self clean - it should shut off automatically when cycle is complete.
BE CERTAIN NOTHING IS IN THE OVEN WHEN YOU TURN IT ON AS IT LOCKS SHUT!
ALSO CHECK TO BE SURE NO ONE USED CHIMERICAL CLEANER IN IT PRIOR -- DANGEROUS FUMES WOULD BE A RESULT
Best regards
Ck
Thank you for your post, Pattie Cromie!
I see that you would like to operate self-clean on your Frigidaire range and you do not have the manual. Typically, to start self-clean you would need to push the button labeled "Self-clean" and make sure there is nothing inside the oven before starting a self-clean cycle. Also before starting self-clean close the door because of the temperatures that are created within the oven the door needs to be closed and locked. I hope this has been beneficial. -Matt
