the message Analog input in power save mode means that your monitor is not getting a signal from your computer.
Maybe you moved the video cable while reconnecting your keyboard? check both ends of your video cable.
If you have a DVI cable, then your monitor has to be switched to digial input.
I hope this helps.
SOURCE: Monitor not receiving data from computer?
If you did not hear any beep from your CPU, then the problem is in the system not the screen.
Try connecting the screen to another computer and try also a working screen of a friend to your computer...
You'll find out that either the screen or the computer...
Good luck... post me back for your result.
Don't forget to rate too.
Thanks...
SOURCE: Dell E173FP stuck in power save mode
What if both the monitor and computer are stuck in power saver? There is no way to get to the control panel. Then what?
SOURCE: Power Saving Mode problem using the DVI input. VGA input Ok.
try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
SOURCE: In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
