Question about HP Color LaserJet CM1015 Printer
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
    New Friend:
    Problem Solver:
  • 5 Answers
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Posted on Dec 11, 2013
  • 304 Answers
Calibrate the MFP from the front control panel.
1. Press Menu.
2. Press the navigation arrows until the display reads System setup.
3. Press OK.
4. Press the navigation arrows until the display reads Print quality.
5. Press OK.
6. Press the navigation arrows until the display reads Calibrate color.
7. Press OK.
8. Press the navigation arrows until the display reads Calibrate now.
9. Press OK.
10. Press OK to confirm Calibrate now.
Calibrate the MFP from HP ToolboxFX
1. Open HP ToolboxFX in one of these ways:
? On the desktop, double-click the HP ToolboxFX icon.
? On the Start menu, point to Programs, point to HP, point to HP Color LaserJet CM1015/1017 MFP Series, and click HP ToolboxFX.
2. In the menu tree for the HP Color LaserJet CM1015/1017 MFP, expand the System Settings
folder, and then click the Print Quality page.
3. In the Color Calibration section, click Calibrate.
Don`t work???
Try this
Restore defaults
This feature resets all menu settings to the factory default settings. It does not reset factory settable settings such as formatter number, page counts, factory paper settings, language, network address, etc.
1. Press Menu.
2. Press the navigation arrows to select Service.
3. Press OK.
4. Press the navigation arrows to select Restore defaults.
5. Press OK.
Or this:
NVRAM initialization
CAUTION NVRAM initialization will erase all network settings. Before performing NVRAM
initialization, print a Network Configuration page, which contains network-setting information.
NVRAM initialization performs the following actions:
? Resets all customer-accessible menu settings via control panel and software back to the factory
default settings
? Resets the language to the value set at the factory
? Resets the default media size to cold reset media size
? Resets the symbol set to PC-8
NOTE The following steps reset the same NVRAM locations that are reset using the Restore Defaults option in the control panel Service menu. The following process should be used if the MFP does not come to a Ready state and an NVRAM initialization is desired.
Use the following procedure to perform an NVRAM initialization.
1. Turn off the printer.
2. Press and hold the Right arrow and Cancel buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
When the NVRAM init is complete, the printer returns to the Ready state.
Posted on Aug 17, 2011
6ya staff
SOURCE:
Picture looks 3d colors not lining up
The tv have a problems known as a convergence picture problems.That why ur tv colors lines R,G,B are mis alignments,have colors shadow pictures or have 3D pictures look alike?The tv convergence board it is dead.Tv Convergence board must have it parts like 2 STK convergence ICS and some or all of resistors to be replace too.To fixed the tv convergence board to solved tv picture convergence problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 09, 2011 | Panasonic PT-53WX54 53" Rear Projection...
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
On the right side of the screen it is turning red and is not aligning properly looks like it is trying to go 3d. what could cause this?
This tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Hitachi 46F500 46" Rear Projection...
Screen looks like it is in 3D colors are seperated.
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergnce board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | Toshiba Televison & Video
Alignment of the bulbs to converge
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | Philips 46PP9302 46" Rear Projection...
Sony model kp46c36 rear projection tv looks like its 3d vision use to correct itself now just seeing double and colors similiar to 3d
there is a problem with your convergence circuits which align the red,green,and blue colors this must be serviced again. sorry.
Jan 30, 2010 | Da-Lite Tensioned Director Electrol 89986...
Red lines out of alignment
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Jan 25, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Colors out of alignment
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 28, 2009 | Marantz PV-6071 60 in. Rear Projection...
My TV looks like if i was watghing a 3D Movie.
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Jan 26, 2009 | Philips 55PP9401 55" Rear Projection...
HP Color LaserJet CM1015 Printer Logo
1,309 people viewed this question
Ekse
Thomas F. Schneider
