Question about Acer Aspire One Netbook 8.9" Notebook
System won't start and don't have recovery disc
    Genius:
  • 1,542 Answers
Hi
you could try this
press the power on key
then straight away tap the alt tab bottom left along with the F10 tab top right
so its
power on
Alt+F10
this will hopefully take you into the factory recovery options
and choose what you want to do
then follow on screen instructions
hope this has helped you
please let us know if it did or didnt
so we may be able to help others
many thanks
Posted on Aug 17, 2011
6ya staff
SOURCE:
System recovery
Try holding alt + F10 at boot. See if this starts the factory restore process.
Jun 14, 2013 | Sony VAIO VGN-NS190J/L 15.4-Inch Notebook...
Computer won't boot stuck in Error RecoveryScreen won't go any further
You should be able to do a clean install of Windows. Just insert the installation disc and press any key when indicated. Optical drive needs to be the first boot option. Go into BIOS and change it is not.
As for disc, you have to use the same Windows version as indicated on the MS Product Key sticker, because of the serial number.
May 24, 2013 | Toshiba NB205-N210 Netbook
My gateway laptop won't reboot after system recovery
I would put in a Windows disc and see if that prompts windows to start and/or reinstall. Actually, can you send me the recovery disc via download? I am trying to fix my old laptop and cannot find the discs. lilly.murphy@yahoo.com Thanks much!
Nov 30, 2012 | Gateway NV55S04u PC Notebook
I forgot my password and i have no recovery disks
Any computer shop can remove the password for you in a few minutes. I use Hirens Boot Disc when I need to do it. But if you don't know what you are doing you can wipe or corrupt the Operating System.
Sep 14, 2012 | Microsoft Windows Vista Home Basic Edition...
Acer Aspiere message says Windows could not finish configuring the system. How do I fix this or get past this
If you received recovery cd's / dvd's or any other restore discs with the laptop you should use them and restore the machine to its original state. If you don't have any such discs you can try pressing ALT and F10 while you turn on the power to the pc repeatedly to see if it starts a the build in recovery feature.
if you can't get the machine to work and you don't have any discs, you should take it to a professional to get it sorted, also if you any any important documents on the machine recovery may delete them from your pc.
Jul 01, 2012 | Acer Aspire One PC Notebook
Averatec 7100 laptop factory recovery disc
Most times the recovery discs don't work. Why not just get an operating system disk and reinstall the operating system?
Have you tried doing a System Restore? System Restore will let you select a Restore Point (date and time) before you started having problems. System Restore will not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the Restore Point you selected). System Recovery on the other hand will delete everything and set your system back to the point when you first purchased it.
To start System Restore click Start/Programs or Start/All Programs. Click Accessories/System Tools/System Restore. When it opens you will have the option to select another restore point (date and time) than the one shown.
May 22, 2012 | Computers & Internet
Hard disk error no recovery disc
@lizegim
HP laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default. The hotkey for the recovery is the F10 key. After you press the power button, you need to simultaneously press the F10 key to start system recovery. If this one won't work and gave you like an "I/O Error" or "Error 0x000000E" or something similar then that means that the HDD is already defective and needs replacement and you need to order the recovery discs from HP at 1-800-474-6836. If you're still under warranty, they'll replace the HDD and give the Recovery Discs to you for free.
Good luck.
Sep 06, 2011 | HP Pavilion A250n (DF253A#ABA) PC Desktop
Where can i get recover disk for my laptop i have a compak it said bootmgr is missing where can i get one or how you burn one on other laptop acer
@ cherylschlei
Compaq laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default. The hotkey for the recovery is the F10 key. After you press the power button, you need to simultaneously press the F10 key to start system recovery. If this one won't work for you, you need to order the recovery discs from Compaq at 1- 800-652-6672. If you're still under warranty, they'll give it to you for free.
Cheers
Sep 03, 2011 | Computers & Internet
I want to know how to restore my hp mini 1000-1151 back to factory settings if the computer doesnt turn on
@ customersvcs
HP laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default. The hotkey for the recovery is the F10 key. After you press the power button, you need to simultaneously press the F10 key to start system recovery. If this one won't work for you, you need to order the recovery discs from HP at 1-800-474-6836 (you need to have an external dvd reader to load the discs). If you're still under warranty, they'll give it to you for free.
Cheers
Sep 03, 2011 | HP Mini 1000 Netbook
Can i use my emachine recovery disk on my gateway after i install a new hard drive on my gateway?
No, you can't. (Well, it might be possible, but very unlikely, that it would work.) Recovery discs are made for specific machines. There are a couple of reasons why the discs for one system can't be used for another brand or model.
In addition to installing the operating system (Windows), recovery discs also include drivers for the machine's included hardware (video, sound, media card slots, etc.). The drivers on the recovery disc for an eMachines system won't have what a Gateway system needs, unless they were built using exactly the same motherboard and other parts, which would be quite unusual. If wrong hardware drivers are installed, Windows may not start and give you the famous "blue screen of death". Or Windows will start, then begin finding new hardware and asking you for drivers you won't have (although you could find them at the Gateway website). The discs also include the applications the manufacturer preloaded on the system. Some of these may not work and cause problems because of the hardware differences (a sound control program with the wrong sound hardware, for instance).
The other reason is that a restore disc also includes information that gets placed into Windows so the system comes up already activated and ready to go. Activation is based on information about the hardware configuration of the system, and yours won't be correct. Windows will see the this and you'll need to activate manually. If the Windows version on the eMachines recovery disc isn't exactly the same as the one on the Gateway, the product key on the computer won't work when you try activation.
Rather than try using the wrong recovery disc, see if you can borrow or download the installation disc for the Windows version specified on the product key sticker on the Gateway. Then you can do a clean new Windows installation and activate it using the product key. You can find the drivers your computer needs at Gateway's website as I mentioned before. It's more work than just running the recovery disc, but it will work. This does mean the system won't have any of the preloaded applications originally on the computer when you're finished. But this is not a bad thing.
Much of the preloaded stuff on a new computer is often called "bloatware", which you really don't need. It just slows the computer down, uses up Windows resources, and may be gathering information and sending it to sites behind your back. You can find good free programs to do anything originally installed and install only what you really need and want. Here are a few suggestions to get you started:
CD/DVD burning: CDBurnerXP
Antivirus: AVG, Avast!
Audio processing: Audacity
Image processing: GIMP
Office suite: OpenOffice
Good luck getting the system back up and running. Thanks for using Fixya!
Jun 30, 2011 | Gateway GT5670 Desktop PC
Acer Aspire One Netbook 8.9" Notebook Logo
55 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
