After a 4 hour cleaning the DOOR LOCKED keeps flashing and the locking motor keeps running - constantly cycling locking and unlocking the door - but the DOORLOCKED Flashing does not change.
Where are the fuses located in the oven? I do not have a self cleaning oven and it keeps saying locked door and kicks off and will not cook again till it cools off. This happens everytime I use the oven.
Operating
Check
that door switch is completely closed. Check latch, solenoid,
and actuation switch for electrical or mechanical malfunction.
Check wiring
and test operation of door lock switch
Check the interlock switch, can be some object has stuck to it...
yes...check that part if this functioning well.. also check for any burned fuses.
let me know
here take a look at this one:
i know it can help u.
What
is wrong with your Range/Stove/Oven?
regards
it can possibly a blown fuse will cause the problem,,,
Hello dennis, this is what i found in the manual;
“LOCK DOOR” flashes The self-clean cycle has
in the display been selected but the
door is not closed.•
solution: close the oven door
LOCKED DOOR light is on when you want to cook.
The oven door is locked because the temperature inside the oven has not dropped below the locking temperature.
solution:• Press the CLEAR/OFF pad. Allow the oven to cool.
tnx 4 using fixya,
drcool
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
is this the same swtich that controls the light? This seems fine.
Where is the interlock switch - is it the same as the light switch on the frame that is closed by the door when shut?
Fuses? Do I need to take the control panel off to get to fuses?
micromaster - could a blown fuse cause the locking motor to cycle continuously? Seems like it would more likely be a sensor that looks for the door to be in the latched position.
The link you provided does not provide any information on my problem.
Where are the fuses?
DO I need to take the control panel off to check for a malfunction latch? If the light goes off when the door switch is depressed does that mean that the door switch is working properly or are there multiple functions of the door switch and I need to remove it to see if it is failing even if the light is turning off?
