SOURCE: HP Officejet 5610 stopped printing
turn the printer on and unplug the power cable from the back of the printer without turning the power off
press and hold :
OK and CANCEL, while keeping them on hold put the
power cable back in ... it ll do a full NVRAM reset on it .. then it ll
prompt u for the language and country follow the steps it ll be
resolved ...
Best of luck
SOURCE: Hp printer 5610 problem Error: 0xd0620230
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect tto wall out let directly dont connect to printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, this should resolve the issue.
Regards,
raj_p5983
SOURCE: HP 5610 officejet all in one: how do i check my ink levels?
Windows users: Turn on printer.....
In the HP Solution Center, click Settings, point to
Print Settings, and then click Printer Toolbox. Click the Estimated
Ink Levels tab.
Mac users:
In the HP Image Zone, click the Devices tab. In the Select Devices area, click the icon for your HP All-in-one. In the Device Options
area, click Settings, and then choose Maintain Printer. If prompted, select your HP All-in-one, and then click Utilities.
Hope this works for you....Eye
SOURCE: Oxd0620230 reset power
my printer is a hp officejet j5750 all in one, the probem is that I can't scan in it, but I can print, send fax, an make copy in it, so the only problem is the scaner, plese help me
thanks.
SOURCE: hp officejet 5610 all in one install ink cartridge
If it's the same as my 6480... turn it off then lift up the top so you can see where the cartridges should go.
Next turn it on with the top still open and the cartridge holder should move into the load position.
Hope this helps.
