Cell Phones Logo
Posted on Aug 17, 2011
How to open GPRS to 5300 ...... - Cell Phones
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Aug 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
2439
Points
54
Restore first the factory settings of your phone first and then ask for GPRS config settings from the network operator, check if it will work. If it doesnt work go to connectivity and delete all existing Access point.. then you retry.
I got an error "only
click on the below link and follow the instruction
http://www.tech2info.com/2011/07/nokia-3110c-music-player-updating.html
it can solve any s40 mobiles music player problem and your mobile also comes in s40 mobile
2answers
My nokia 5300 sHow is only 70 sets allowed setting discarded when i want to save new service setting for gprs?
There are many settings saved in your phone.Delete the unwanted settings and save the new setting
Thank You
15helpful
3answers
Unable to save gprs settings in nokia 5300 mobile phone, where configuration settings are empty. it shows "only 70 sets allowed settings discarded".\r\nwhen i want to create personal configuration it shows...
Unable to save gprs settings in nokia 5300 mobile phone, where configuration settings are empty. it shows "only 70 sets allowed settings discarded".\r\nwhen i want to create personal configuration it shows "can not add new account, memory full". please help me immediately.........
I cant open my gprs how can i open this
by holding 0 button on nokia opens the browser, but you should make sure you have subscribe to gprs with your operator and you have recieved and saved gprs settings in your handset.
thanks
5helpful
How to open the GPRS and MMS of nokia 5300 classic
related to this problem
in some sim card its preactivated gprs sevice available
you just hv to choose the correct access point.
for example : if you are using 'Idea Cellular' then the correct access point for gprs is 'IDEA INTERNET or IDEA FRESH ' you can check these settings by going WEB/SETTINGS.
IF ITS NOT PREACTIVATED THEN
just call your sim card service provider (customer care )
and ask them to activate gprs and mms service on your number
after getting activation
then on your mobile phone to to menu/web
now your can access any site on your mobile
and about mms it easy to use its just like using sms
I have problem in opening my globe gprs..
kindly call to your connection customer care !!! ask them how to activate ur GPRS they will insist you to send a message to a particular number !!! send it !!! after sending it u will receive a GPRS settings with in 24 hrs !!!! then u can save it just by pressing k button & start accessing ur GPRS
Can i chnge from edge to gprs
The EDGE and GPRS are data transfer methods used by network operators.EDGE is 3 times faster than GPRS.Usually network operators use one of the two.Actually you are not deciding the method.Either you can enable or disable it.
I can't open mms on my phone 5300
hi thanks for using fixya!
I recommend that you should contact your network service provider so that they can provide you the GPRS configuration and settings.
If you need further assistance, let me know.
1helpful
2answers
Nokia phone wont connect to the GPRS
Creating Data Accounts
Steps:
1. Open Services Menu.
2. Open Data Account.
3. Open GPRS.
4. Create/Edit Data Account and enter the following values:
For Globe MMS Data Account:
Account Name: GlobeMMS
APN: mms.globe.com.ph
User Name: leave it blank
Password: leave it blank
Auth. Type: Normal
For Globe GPRS Data Account:
Account Name: GlobeGPRS
APN: http://www.globe.com.ph
Auth. Type: Normal
For Smart MMS Data Account:
Account Name: SmartMMS
APN: mms
Auth. Type: Normal
For Smart GPRS Data Account:
Account Name: SmartGPRS
APN: smart1
Auth. Type: Normal
5. Save the Data Account.
Configuring WAP/GPRS/Internet Services Using the Data Accounts Created
2. Open WAP.
3. Open Settings.
4. Open Edit Profile.
5. Create/Edit a Profile and enter the following values:
For Globe GPRS Profile:
Rename Profile: myGlobe GPRS
Homepage: http://www.globe.com.ph/globe.asp
Data Account: GlobeGPRS (this data account is the one you have created)
Connection Type: HTTP
Proxy Address: 203.177.042.214
Proxy Port: 8080
Username: leave it blank
For Smart GPRS Profile:
Rename Profile: SmartGPRS
Homepage: http://wap.smart.com.ph
Data Account: SmartGPRS (this data account is the one you have created)
Proxy Address: 010.102.061.046
Proxy Port: 8080
6. Save the Profile.
7. Activate the Profile.
8. WAP/GPRS/Internet services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
Configuring MMS Using the Data Accounts Created
1. Open Messages.
2. Open MMS.
3. Open Message Settings.
4. Open Server Profile.
For Globe MMS Profile:
Rename Profile: GlobeMMS
Homepage: http://192.40.100.22:10021/mmsc
Data Account: GlobeMMS (this data account is the one you have created)
Proxy Address: 192.040.100.020
Proxy Port: 8080
For Smart MMS Profile:
Rename Profile: SmartMMS
Homepage: http://10.102.61.238:8002
Data Account: SmartMMS (this data account is the one you have created)
Proxy Port: 8080
8. MMS services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
