Flashing is the only solution, but anyway Remove Memory Card,Sim Card and reboot by inserting only the battery.Try it for 2-3 times.If the problem still persist better to contact mobile repairing shop or follow this trick. First download and install
Pheonix from this link. Nokia
Phoenix Service Software 2011 - Download secondly Download flash file from this link 5130 flash file and install it to C / program
files/pheonix.. after finished this installation open pheonix . Inside the
interface at the> top left
<there you see "File" click there and choose "open
file" and then select the approprait Product type i.e
"which is written on the back panel inside the battery of every Nokia(Type
RM-000).After doing this again at the left top count from
"File"1..2..3..the 4th one is "Flashing" press there,
when you click there you'll see three sub-menus, just select the "Firmware
Update" again you'll see another interface. Look at the product code
there should be blank and put your "mouse tool" at the straight end
from the "Product Code" there is a Button and
choose the code which is written in the back side of your phone. e.g CODE:0000000.if
the same code does not found just take one which is higher. After this you can
see "Dead phone USB flashing" click that box. Now this is the
last stage... Connect your phone with the USB to your PC and let
the driver install ...wait for a moment.(If
your phone working).Lastly after just finished (In case your
phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish"
button after this, a message will prompt you "press power botton"
etc. insert charger or press it and wait
until the phone will Restart automatically in normal mode 10-15 minutes. If you
cannot understand just leave a Comment. thanks for visiting fixya. Good
luck.
