Hi,Even
though you have not mentioned about the cabling connections you have done, for the sake of correct
connection I describe all the possible cabling alternatives to you..You
can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or
"Optic cable input " or HDMI IN connector of your TV ,
** than just switch to
DVD mode on Receiver and play DVD
*You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or
"Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input" or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
respective SOURCE mode on Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
You did not mention if the sourrround was an external speaker connected through a DTH amplifier or if this was on the TV. Now to activate the surround the menu must be opened and the audio settings page opened.Now check if the surround settings was activated. Also check the surround speakers .
Please mention the details of the TV, make /model.
Also only if a DTH mode is selected with a DVD with DTH will the surroung work perfectly. So check this out.
Sir try to look at the back of your tv and look for the audio out, connect the cable of your surround sound into that port if still no sound try to check the cables you are using or use another cable feel free to send feed back good day and best regards.
If the connection is in proper places try to check if there is a switch in the surround sound speaker that may be deactivated.
sir can i have the model number of your dvd thanks.
Sir can i have the model number of both units. thanks
Are you using a wireless receiver for the surround speaker?
Sir sorry for the late reply. Sir try to use the test tone features in the sound setting to be sure that all the speaker are connected properly.
Sir Im sorry but I think that the problem of the unit is only in the setting and the connection of the unit or the sound compatibility Sir try to review the user manual of your unit. I'm really sorry I can't help.
I have an HDMI cable between the dvd and the tv, so that should connect all the audio and video in one? and we have checked all the settings so that it should work, but again, the tv won't play through any of the speakers connected to the dvd, and the dvd will only play through the front two speakers and the subwoofer, but not the surround sound speakers or the central speaker
Hi, as I have and HDMI cable attached from the TV to the DVD player, and Anynet is working, so that the remotes are compatible. But still, when the TV is on, the audio is not coming through the speakers that are connected to the DVD player, and when the DVD is playing a DVD, the sound is only coming through the two front speakers and the subwoofer, and not the center speaker or the two surround sound speakers. Now I have also done a speaker check, and they are all working, so I don't know what the problem is
There is no switch on the speakers, all the speakers are working when they were tested, and all the connections are working properly...but for some reason, they won't work together. Any other ideas?
They are both samsung. The DVD is HT-D5300.
The TV is series 4+, 43cm, looking for the serial
Number now
No, I'm not using a wireless receiver for the surround speakers. I have bought an optical cable now to allow the TV to play through the surround speakers, as advised to me by somebody who has a samsung TV. However, I have not yet found a solution as to why only two of the five speakers are transmitting audio when they are all calibrated and work individually...
The model number for the blu ray home entertainment system is HT-D5300, and the TV is a compatible samsung 4+ series, 43 inch screen
Hi, I told you I already did that. I ended up calling a samsung tech and he told me what to do.
It was a button on the remote control that needed to be pressed to switch between
Different modes that use different speakers...
