SOURCE: Flip video problem
I have had this exact problem. The Flip Camera read "empty" however if I tried to record something by pressing the red button, the camera read "full." I started having this problem and kept on seeing fewer and fewer minutes available to record. Today, I was trying to shoot and then uploaded three videos. I could use the camera no more. So, I did as you suggested...plug the camera in to my Mac and then emptied the trashcan. It WORKED!! I got all sixt minutes back.
SOURCE: Camera software corrupted??
I had the same problem with my flip mino HD. Here are the steps I took to fix it.
1. Adjust the power options on your laptop to ensure it does not sleep/hiberate ever.
2. Reset the camcorder by inserting a paperclip into the hole in the
tripod mount. Hold the paperclip in there for about seven seconds.
3. Then immediately plug the flip into the cpu.
4. You may not see anything besides the little blinking white light on
the USB arm for a while (about 30 minutes maybe) but leave it in.
5. Eventually it should spring to life and show the recharging battery
on the little screen (the Flip Share program may start too.)
6. Leave it charging until the little white light stops flashing - full charge about 3 hours.
7. You can then remove the flip and change the power settings back to normal.
SOURCE: Flip Video Won't Turn On
For the Flip Ultra - Take out batteries you should see a flat somewhat square piece of metal with a small black piece sticking up from it. Take a pencil and push the black piece down wait a few minutes then try turning your flip back on.
SOURCE: my flip video won't turn off or record, won't be
To fix, I held the on/off button down for an extended time (around 10 secs approx) until it finally turned off. Left it alone for a few minutes and then turned back on. Worked okay. Also got a response from flipshare support who said there is a reset button inside the tripod space, use a pin to press that and then fully recharge camera via USB slot on PC.
SOURCE: My flip ultra won't turn on even though i've had
Do you have standard batteries or the rechargeable batteries?
If standard, change them.
