Error code E552 is usually caused by a communication issue between the CMM and the computer. You can try restarting the CMM and the computer, and ensuring that all cables are properly connected. If the issue persists, you may need to take your CMM to a certified Mitutoyo service center for further diagnosis and repair.
You will need to loosen the cable adjustment off all the way. Then you will need to remove the snap ring and pull the pin out and then pull the handle off and remove the nylon pin to release the cable from the handle and do not drop any of these parts and then put the new lever on, reinstall the parts in the reverse order and adjust the cable so there is 1/16 to 1/8 inch freeplay at the cable and perch area.
For some reason, if you have Adobe's CMM installed on your computer, the Media Converter for Philips is unable to start up and will error out every time. You have to uninstall Adobe's CMM (any version), once you do that, the Media Converter for Philips by ArcSoft will work as it should. I found this conflict when I viewed the error in Windows Event Viewer where it listed that the conflict was being caused by the Adobe CMM.dll, I uninstalled Adobe's CMM from my system and the media converter works fine now.
No, The mower requires an external charger to charge up the battery. I look and there a five different types of that machine. However, I did find a part number on the charger for the first model is #90505885. HTH Good Day.
hi check this http://www.orkut.co.in/Main#Community.aspx?cmm=20844581 or http://www.orkut.co.in/Main#Community.aspx?cmm=39782113 or http://www.orkut.co.in/Main#Community.aspx?cmm=35281212
