Question about Mitsubishi WS-65809 65" Rear Projection Television
Hello, 2 years ago you have posted the info on how to repair ws-65869 "This model uses a single convergence IC chip---- STK-393-110. The chip needs to be replaced and there are about a dozen light blue resistors in front of it that need to be checked also." there was an offer to send the instruction on how to repair it. Is it possible to obtain them please?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 360 Answers
Please download the service manual from the following link. It is a two part download. You will find the instructions to repair it. http://www.eserviceinfo.com/downloadsm/37352/Mitsubishi_WS-55859,%20WS-65869,%20WS-55909,%20WS-65909,%20WS-73909.html
Posted on Aug 16, 2011
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Yes there is: it is not permitted for experts here to ask for a email address......I am the one with the instructions.
The alternate way is to email Lauren@fixya.com and ask for her to act as a go between; she will email me, I will send the instructions and she will forward them to you.
SD TECH
  • SD Tech
    SD Tech Aug 16, 2011
    The instructions tell you everything you will need and step by step how to do the repair.
  • SD Tech
    I have forwarded the instructions and some photos to the community manager; if you need help or have any questions comment here and I will assist you.
    SD TECH
  • 587 Answers
Buy the IC online search using google
The resistors almost never need replacing. But each is marked with a value in Ohms.
They are low Ohms like 2.2Ohms or 3.9Ohms.
If one is bad it will look burnt usually.
Install the IC chip and if one color won't adjust check the resistors with an Ohm meter.
either the ohms is written on the resistor or there is a color code on eem
Best of luck
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
6ya staff
SOURCE:
Yellow and blue shadowing, double image
It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.
WS-55511 uses a single convergence IC chip---a STK-393-110.
IF convergence is off and will not adjust it needs along with any of the 3.9 ohm resistors that protect it to be replaced.
What happens in these and most projection sets is the chip is mounted on a large metal heat sink with fins to keep it cool----a white grease is applied to the back of the chip to quickly transfer heat--after some years the grease dries out from the heat and the chip fails.
Considering you can buy the IC on Ebay for about 14 dollars plus shipping (I can tell you the best seller there to look for) if you or someone you know can do the repair you can save the set and a LOT of money.
Most shops are going to get 200-300 for this repair
Dec 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
There is a arch across the top and bottom of the screen , and everything has a blue outline.
Either the convergence alignment, wich can be repair by the owner...with the remote (tough not a simple task), or you have to change the convergence hybrid IC (STK chip)...if any or the convergence board itself.
Aug 11, 2010 | Mitsubishi WS-65869 65" Rear Projection...
My t.v looks double red leters
This model uses a single STK-393-110 convergence IC.
If red is skewed and or bowed etc the chip must be replaced.
It is located on the middle board and can be a do it yourself repair.
Part will cost about 14 dollars on EBAY.
I also have start to finish, step by step instructions for this repair in this set. They tell you everything you will need and how to do the repair. They are based on my experience at doing this repair in hundreds of these sets.
Let me know if you want the instructions, they are free and I can post them here for you.
If this information helps you decide what to do rate this solution as I do this here for free.
REGARDS, SD TECH
My blue will not adjust up and down. It will adjust sideways. I try to converge my tv, the red is working properly but the blue will not adjust vertically. It will only adjust horizontal.
The model indicated uses a single STK-393-110 CONVERGENCE OUTPUT IC. The chip is most likely the problem(98%) and I know as I have changed hundreds of them.
The part is about 14 dollars from a seller I use on EBAY.
I also have start to finish, step by step instructions for doing this repair in this model.
They tell you everything you will need and how do do the repair.
The repair involves getting the center circuit board out of the set and replacing the IC and examining some blue resistors in front of it to make sure none opened.
Let me know by responding to this post and I can either post the instructions here or email?
SD TECH
Apr 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The red part of the picture is curved and separated from the other colors.
If you go into the customer menu and select convergence--then advanced(there will be instructions on screen) and red or blue are skewed and will not adjust--you have a convergence circuit problem.
The WS-55511 you have indicated uses a large single IC chip for this---a STK-393-110. SHOPS get 300 or more for this but you can buy all the parts needed for under 30 dollars--one seller I use on Ebay has that chip for 12 dollars.
If you confirm you have a convergence problem and want to try to fix it yourself---I have START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS MODEL.
They tell you everything you will need and how to do it.
If this information helped you rate this solution as I do this here for free. If you want the instructions I can post them here.
SD TECH
Dec 20, 2009 | Mitsubishi WS-55511 55" Rear Projection...
The colors are blurry and will not converge
This model uses a Single convergence IC---a STK-393-110.
If convergence is skewed and will not adjust the chip needs to be replaced.
Most shops get 300 or more for this repair---you can buy the IC on Ebay for about 12 dollars--total parts cost should be under 30 dollars.
I have Start to finish, step by step instructions for this repair in this set--they tell you everything you will need and how to do the repair.
Let me know if you have questions or want the instructions.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 19, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Picture is bowing at top and bottom also has shadows and has converance problems and lines on tv be red and white
ws-65869?
STK-393-110.
Considering you can buy the part on Ebay for about 12 dollars plus shipping---if you or someone you know can do it for you, you can save the set and a lot of money.
I have done hundreds of these repairs and I have had so many people here asking that I composed step by step-----start to finish instructions for this repair in this set----
The instructions tell you everything you will need to do the repair and are detailed.
I just today received a comment from someone who got the instructions tell me the repair went perfect and he now has a working TV again for a fraction of what a shop wanted to repair it.
If you want the instructions let me know, I am not allowed here to post MY email address, but you.....
If you have any questions or need advice let me know.
I am here to help people, I do this here for free.
SD TECH
Oct 28, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Appears convergence is not working. when i use the video button to see the convergence lines at the top and bottom of the screen the lines are curved which is causing the color and letters to be off on the...
WS-65511?
STK-393-110.
SD TECH
Oct 28, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Convergence goes out and image convexes cycle on and off sometimes resets
This model (WS-65869) uses a single large convergence chip that commonly can cause this kind of trouble--I have seen dozens or them where convergence comes and goes from bad to good etc.
The IC is a STK-393-110 and I just received some from a source on Ebay (they cost about 12 dollars plus shipping)-----
The hard part of this repair is the center circuit board needs to be removed to do this repair----if you think you can do it----it involves soldering etc--let me know by rating this solution and I will post the instructions here for you.
If you cannot do this repair--shop around your area--most shops get 300-400 for this type of repair; if they say it has to go to the shop--keep looking as any good tech can do it right in your home in about one hour.
I have done hundreds of these sets and after the IC is replaced and the set adjusted--you will not have the same problem for 5-8 years (life span of this kind of part).
Let me know if you have ANY questions---I am here to help people.
Regards, SD TECH
Oct 11, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Convergence
i have tried this replacement on philips 43 inch. convergence ic part # is STK-392-120. it is mounted on a big heatsink, replace this 2 IC at one time. soldering is not difficult. 1. you need desoldering tool (**** type) 2. soldering iron of 40W 3. and silicon grease for greater transfer between IC body and heatsink. i bought that personally in asia for less than 50USD on two IC with same part # . let me know if there is any other thing i can do.
Apr 02, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
