Sal De
Go here,put your model number in to see all parts in your washer,if you think you can change out the hose then do it,find the hose on the diagram,get the part number and order it,or the hose could have pulled off from an unbalanced load but you're looking at it,if it has a hole in it replace it,if it just has to be realigned then do it.this ain't heart surgery lol.just unplug the washer before you open it up.good luck with it.
SOURCE: My LG TROMM (WM1812CW) does
check out lg's site page 21 or 23 and it will tell you what the error code is as well as how to fix it. http://us.lge.com/download/product/file/1000000200/WM1814CWowners.pdf
SOURCE: error message displayed on LG tromm washer model # wmt2778w
Flashing UE - The display shows:
• Load is too small.
• Load is out of balance.
• The washer has an imbalance detection and correction system. If individual heavy articles are loaded (bath mat, bath robe, etc.) and the imbalance is too great, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and the error code will be
displayed.
Possible Solution
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
• Control error.
SOURCE: How do I remove the
There are special pliers for removing the spring loaded wires which hold the front and back side of the gasket in place. You're better off cleaning it in place if necessary. If you have small, inconsistent water leaks, the problem is suds in the fill hose, between the soap dispenser and the tub. There is a small dome at the tub inlet inside the hose which can be removed, but just using HE soap and making sure to use only one tablespoon per load should solve the problem.
SOURCE: LG WM2487 front load washer spews suds out of port on rear.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
SOURCE: lg wm0642hw drain hose in front is pluged with
That's a real pain. Even if you remove the hose, it is hard to clean out. You can get at the pump end of the hose by tilting the machine back and reaching under it. Replace the hose will save a lot of time, or I'd suggest next time you want to clean out your filter do this:
Pull the machine out about 18 inches or so away from the wall and tilt it back until the back rests against the wall. (front feet now up in the air) Now, all the water will be back at the back of the machine and you can remove the filter to clean it out without spilling water.
