What is 1mm double core?
Following image shows example 120Volt 4 gang switches with outlet.
http://waterheatertimer.org/images/Single-pole-switches-in-4-g.jpg
Each 120Volt electrical box has one Hot wire. This is true for ceiling and wall boxes.
Normally in a gang box, the Hot wire jumpers across all devices in the box.
Some switch boxes do not have Neutral wire. Neutral wires are usually white, and are twisted together and covered with wire nut and shoved to back of box.
Open following links for typical 120V and 240V circuits in US.
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Feel free to add a comment and describe wiring, and voltage.
For example if hot wire arrives from one of the lights.
Describe the wires that you have, and what each wire goes to for best possible answer.
