Televison & Video Logo
Posted on Aug 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a 56" RCS
Chi Chu
Level 3:
  • Televison & ... Master 8,457 Answers
  • Posted on Aug 16, 2011
Chi Chu
Level 3:
Answers
8457
Questions
0
Helped
2822763
Points
26282
The tv have a problems known as a convergence pictures problems.Tv have any colors lines R,G,B mis alignments,have tv pictures colors shadows or tv pictures 3D look alike?Yes,this problems the tv convergence board it is dead to causes this problems.The tv convergence board must have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
NEED PART NUMBER FOR PROJECTION HDTV. MODEL R56WH78 FOR THE PROJECTION BULB
Good Morning
your set does not have a bulb it has three CRT'S picture tubes . and if the set is not working its not likely that the crt's have all failed . you most likely have a circuit failure like a high voltage trippler block or some where else in the set . what are the symptoms at start up .
Convergence color has a rainbow effect
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Television has a rainbow effect
RCA HDTV floormodel, model # : HD52w59. The picture does not come in well at all, and the menu is distorted, it seems maybe there might be a bulb out in the left side but I am not sure, how would I fix...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
The blue is not lined up with the rest of the picture
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Will not focus
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Getting 3D effect in picture is there a way to adjust lamps to fix problem
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
When switched on colours fine after short period colours seperate causing a 3d type effect
3d tv!!!
Hitachi projection hdtv has 3d effect and bowed shape
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
