SOURCE: Rolex runs down
sounds like you need a new watchmaker, Your watch is designed to be worn 16 hours a day an rested for 8 while you sleep and this should keep it running. there are several different mainsprings that can be installed depending on the age and your activity level. I would be happy to take a look at it for you. Donald McPherson Certified Watchmaker AWCI www.finewatchmaking.com
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
unscrew the winding pin until it opens to the first position. (this position is for self winding. approx 30 turns clockwise will fully wind the watch)pull pin to the next position. this sets the date if it is a quickset. 1985 to present. again turn clockwise to the desired date is present. pull the pin to the final position and this will set the time turning clockwise as well. hope this helps.
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
SOURCE: does anyone have a manual for a datejust rolex
No, there isn;t any downloadable manuals for Rolex watches, but operation of Rolex Datejust is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in date setting position,
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
SOURCE: how do i wind and set my Rolex Oyster Perpetual watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
2)
when you pull out the crown to the first click, it is in day and date
setting position (depending wich way you turn the crown).
NOTE: to
adjust the day or date, previously you have to advance hands forward,
passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m.
using the crown in position as described in chapter 3. When done - push
the crown fully in, then pull out to the first click and only then
adjust the day or date.
To
daytime (noon).
After all settings being done, always screw the crown back down as it protects the watch from water and moisture.
