Panasonic NN-S254BF Microwave Oven Logo
Posted on Sep 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MICROWAVE NNS541BF MICRO FUNCTIONS ALL WORK BUT ONLY RUNS FOR A COUPLE OF SECONDS I WOKE UP ONE MORNING AND DISPLAY READ (CHILD) WHATS THAT
William Miller
Level 3:
  • Panasonic Master 9,179 Answers
  • Posted on Sep 16, 2008
William Miller
Panasonic Master
Level 3:
Answers
9179
Questions
Helped
4478336
Points
21747
That would be the child lock.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
LG Microwave MC8289UR/00 want to know if has child lock and how to turn on and off
Here is a section of the manual for your microwave on child lock, hope this helps.
"L" - Page 7 Press and hold STOP/CLEAR until " L " appears on the display and a BEEP sound is heard. The CHILD LOCK is now set. The time will disappear on the display . To cancel CHILD LOCK press and hold STOP/CLEAR until " L " disappears. You will hear a BEEP when it's released. If any button is pressed, "L" will appear on the display Your oven has a safety feature that prevents accidental running of the oven. Once the child lock is set, you will be unable to use any functions and no cooking can take place. However your child can still open the oven door. Press STOP/CLEAR. Child Lock 7
Genius S333 refer to manual error after 3 seconds
If microwave runs only without turn table, I am suggest to check if turntable electric motor has got short circuit. If yes, I have some left.
1helpful
1helpful
My Frigidaire microwave display reads "LOCK" and it will not work. What should I do?
If it is still locked or goes into lock mode by itself, the "clear" key on your keypad may be shorting.
Here's how the child lock works on model FMV145:
Child Lock-Out
You may lock the control panel to prevent
the microwave from being accidentally
started or used by children.
To lock or unlock the controls, press and
hold CLEAR/OFF for about three
seconds. When the control panel is
locked, an "L" will be displayed to the
extreme right.
You can find your manual here.
If you think the controller or keypad may have failed, see us here or order parts here.
Lock function reset for model JMV8208BAS
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
The owner's manual is online here and it covers the child lock:
To set the child lock.
Touch and hold
ENTER/START
pad more than 3
seconds. CHILD
LOCK ON will
appear in the display
window with two
beeps.
To cancel the child
lock.
Touch and hold
ENTER/START
pad more than 3
seconds. LOCKED
will disappear and
you hear two beeps.
1helpful
Error message "chiLd"
There is a Child Safety lock-out feature on some microwave ovens. This enables the user to lock the keypad to prevent children from playing with the control panel. The model number you have this question posted under has this feature enabled/disabled by pressing and holding the "CLEAR/OFF" button for 3 seconds. However, the display reads "LOC" when the feature is activated. I suspect your model number is different because of the display indication you are receiving. Review your owner/operator manual for how to disable the child lock feature. If you no longer have the owner's manual, or if you still have questions, please post back with your BRAND NAME and MODEL NUMBER, so that I may be able to provide you with better assistance. I hope this helps you.
7helpful
2answers
Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
67helpful
7answers
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Starting by itself
Time for a service call. Should not turn on by itself at any cause. Circuit board is my guess. May be cheaper/easier to get new microwave. My first one lasted about 15 yrs--and the circuit board (touchpad) died. Bought new microwave oven.
Top Panasonic Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
