Callaway CY2058 Sport Series Watch Logo
Posted on Aug 15, 2011
I need to change the battery of my watch and i don't find the place for removing the back cover
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Aug 15, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
2198
Points
8
Some watches have a notch that comes out where you can get a knife, or exacto blade underneath to pop it open. if not, there may be multiple intends along the ridge that would require a special tool to twist open. any jewler could change the battery for you. also, batteries plus stores can change the battery out at a reasonable price.
2answers
How do I change a westclox Scotty pocket watch battery
Take it to a jeweller/watch-clock maker or remove the back for access.
Where i can replace the battery of my Casio watch,.Casio hunting timer AMW 705
The battery of my Casio 1846 W-71 was dead, so I tried to replace the battery by myself.
First, you need to get a hand on a CR2016 3-volts battery. It could cost you 5$ or 10$, but I got 5 of them for 1.50$ at an electronics discount store...
Get a precision screwdriver, remove the 4 screws. Be careful when you remove the cover, there's a tiny spring. Remember where it is, then remove it. Remove the watch from the shell.
Using a flat mini screwdriver, remove the cover that holds the battery. You'll need to unclip all 4 corners. There are centers to unclip too, not sure if there was 2 or 4 of them.
Remove the battery, place the new one. Clip the battery cover back, and put the watch back in the shell.
I closed the cover. The watch was showing time, buttons were working, but no sound at all. Looked on the Internet, and read that you need to short circuit it.
Look carefully, there is a label "AC" near a small hole. (Inside the hole you'll see the gray spike of a welding). Just touch something metal inside the hole (e.g. the welding spike) and then touch the positive (top) side of the battery. Put the cover back in place, press a button and listen for the beep.
Screw the cover back in place.
Aug 23, 2013 • Watches
1helpful
I dont know how to change it
Hi Mateo,
I suppose you don't know how to open the backside of your watch, to replace the battery.
If that is so, check the back side of your watch. At the edge of the centre cover, or just under it, there is at 1 place a little notch of a view millimeters. Juse a small screw driver or tweezers for instance to lift it up. If you don't succeed, the cover might be tight and sticky. So you need to put the back side of your watch on a hot and wet cloth. That might help to loosen the sticky edges.
Good luck ;)
Andre
Oct 20, 2012 • Watches
3helpful
2answers
How do you change a watch battery
Pretty sure you just pop off the back, take out the old battery and put in a new one. Stores that sold watch batteries use to do it for you, some don't now. Liability reasons they say.
Mar 11, 2012 • Watches
How to remove oasis watch battery back
To remove the battery from the back of an Oasis watch, you will need a small flathead screwdriver or a coin.
  1. Locate the battery cover on the back of the watch. It is typically located at the 6 o'clock position.
  2. Insert the screwdriver or coin into the notch on the battery cover.
  3. Gently pry the battery cover off of the watch.
  4. Remove the battery from the watch.
  5. If you are replacing the battery, insert the new battery into the watch, making sure that it is oriented correctly.
  6. Replace the battery cover by aligning it with the watch and pressing it into place.
If you are having trouble removing the battery cover or if the watch has a different type of back, you may need to refer to the manufacturer's instructions or consult a professional watch repair service. It is important to handle the watch carefully to avoid damaging it.
1helpful
My battery is running dead . Can I have it replaced ?
Yes, the battery for this watch can be replaced. Timex estimates that the battery should last 2-3 years, but that assumes an "average" use of the Indiglo backlight. If you never use the backlight or audible alarms, your batteries would have lasted longer; heavy use of both would have run the battery down more quickly.
If you want to replace the watch battery yourself, you'll need a very fine philips or flathead screwdriver, the new battery, and a bit of patience. It would also be helpful to have a pair of tweezers, but that's not absolutely necessary. If you carefully look on the back of your watch, Timex usually lists the battery type so that you can buy a replacement battery without first opening the watch. If you can't figure out what the numbers mean, take it to a jewelry counter at Target or Walmart, and they should be able to help you decipher it. I don't know which battery this specific watch takes, but many Timex watches use a #1620 or #2016 3v battery. Look for a number like that on your watch back.
To open up the back of the watch, open the strap so that you have good access to the back. If you have a steel band, you might need to slip out one of the adjustment pins to separate the band into halves. Yes, you might be able to take the back off without this step, but it makes it a lot easier.
Place the watch face down onto a soft surface. I like to use a dark towel, so that if I drop one one of the tiny screws you'll be dealing with in a minute, they won't bounce and you can easily find them again.
Use your screwdriver to loose the back of the watch, one screw at a time. I find it very helpful to loosen a screw, then use the tweezers to pick it up out of the hole. These guys are tough to grab with your fingers! Put the screw in a safe place, then carefully remove the back of the watch. A little black neoprene gasket may be stuck to the back or be floating around--don't lose that!
You should be able to see where the battery is kept. On most Timex watches, there's a metal shield covering the watch and completing the power circuit. Using your screwdriver, gently pry the tabs of this shield away from the watch movement, one tab at a time. Try very hard not to snap off any of the little plastic anchors. On a Casio watch I recently serviced, I had to remove the movement from the watch to get at these little tabs; I don't remember ever having to do that with a Timex.
Once the shield is loose or removed, the battery should slide right out. Replace the battery, and gently snap down the metal shield. Turn the watch over to check whether it's working again. If it's not, you may have to push a little "reset" pin on the watch movement to clear the registries. The back of the metal shield usually has instructions on where that little pin is located. If the watch is already working, you won't need to do this.
Closing up the watch is the reverse of what you did to get it open. Make sure the neoprene gasket is back in place--that's what's keeping sweat and water out of the watch--and carefully set the cover back in place. Tighten the screws in an "X" pattern--i.e., top left, then bottom right, then bottom left, then top right. I get all the screws loosely screwed in before tightening them down in earnest. This watch has a plastic case, so you want to tighten the screws snugly, but not over-tighten them so that they strip out the screw hole.
2answers
How can i tell a fake from authentic?
mcdevito75 here, Best Bet is to look for a small watch repair shop in your area, they can authenticate your Gucci watch for you. If you can, remove the back cover of your Gucci and record any and all numbers and other info off the watches movement itself then check online at Gucci.com. If your not familiar with watches, specially Gucci an expensive watch let a small watch repair shop remove the back cover and give you all info needed to authenticate the watch.
How do i change the battery in a timex wr 30 m watch
remove back cover plate- inside you will need a jewlers screw driver- install new batery in reverse. install screw- and snap cover back in place.Make sure battery is new.
Top Callaway Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Callaway Watch Expert? Answer questions, earn points and help others
