Hello, would you happen to have the model number of your range? As to what could be the issue why your unit is not lighting it could be each individual ignitor or it could be the spark modulator in the unit is not sending the spark to the ignitors. You could also have a break in one of the wires that goes from the control to the switch or, you could also have a bad switch that has arced closed preventing the flow of electricity from traveling past the first switch as most switches are wired in a chain from one to the next. You will need a multimeter and to be able to perform tests measureing the flow of current as well as be able to perform continuity tests on the switches as well to assure that they are functioning properly. A question if you were to use a lighter to light the burners does the burner light and if it does does the flame travel around each of the burners as well the reason I ask this is sometimes carbon can build up on a burner preventing the burners from lighting. If you have any further questions message me back and I await your reply Thanks Rick
