Televison & Video Logo
Jim Nagel Posted on Nov 12, 2005
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No settings memory,turns on by itself?
Timer programming light is blinking,I program the television for time/date all ok... turn televison off, turn back on and it goes into programming mode at times cc mode turns on by itself,the t.v. turns on by itself. It just will not stay programmed the way I leave it..
Anonymous
Level 3:
  • Master 1,476 Answers
  • Posted on Jun 22, 2006
Anonymous
Master
Level 3:
Answers
1476
Questions
0
Helped
340446
Points
4062
Sounds like your set has a bad eprom. This is the brain that stores all the settings and sends information to the microprocessor to make things happen. If you do not know how to replace it you should take it to a qualified tech to repair it.
Hisense tv troubleshooting
Check the tv menu settings...go to where you set the date and time etc... usually in the general section..
Look for timer or timers...turn off sleep timer, turn off power on timer and turn off power off timer...cheers
1helpful
Wickes 7 day digital timer. I can set the time and date, but how do I set the timer?
1) Copy following link to identify timer and download manual:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#451
2) Don't forget to press reset button before starting to clear memory traces.
Each program must have ON and OFF time.
After setting current time, and pressing SET button, it appears you press the A+ button until 1 and ON show on display ... this is program1 ON.
Then it appears you press SET button and days of week will flash for Program1 ON. Cycle through choice of day(s) you want for program1 ON.
3) Add comment and say what you find, for further interactive help Jan 2013
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I have a double pol 208 dgm100 and i conect whith contactor and i cant able to program please can you help
Tork digital timers and manuals appears on following link
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DGM
DGM100 programming manual:
http://waterheatertimer.org/pdf/TORK.DGM100.INSTALL&OP.pdf
DGM100 is single channel timer, so timer operates all Loads at same time.
In other words, if you have 2 different contactors, the timer cannot set different schedules for each.
7-day programming
32 set points
Programming buttons:
1) When powering up the unit, model number 100P appears on screen.
LCD displays 12H which is an automatic (AM/PM) format.
Press ENTER to keep 12hour am pm -or- press HOUR to change to military time, and then press ENTER
2) Unit is in RUN mode and time displays.
3) Set current time:
Press DAY/Month key to select current Day.
Press HOUR key to set current hour (with AM/PM).
Press MIN key to set current minutes.
Press ENTER key to confirm.
Unit now stores present time. Seconds are set to zero.
4) Daylight savings time (DST) automatically adjusts for daylight savings time, if you choose this option.
In step 3 you set current time, but you did not set the Month and date.
YES DST: If you want DST then follow step 5 and enter Month and date.
NO DST: If you don't want DST, then skip Month and date, and move forward to step 6
5) Set month and date.
Press MODE until DATE displays
Press Month button to set current month
Press Date button to set current date
Press ENTER to confirm
6) Set programs
Press MODE key until SET displays
Display shows --:-- 01 which is program1
-Press DAY/MONTH key to set day(s) you want program1 to turn ON
Following are choices that display on screen:
MO to FR (MO, TU, WE, TH, FR)
SA and SU (SA, SU only)
MO to SA (MO, TU, WE, TH, FR, SA)
SU to SA (SU, MO, TU, WE, TH, FR, SA)
Individual days: SU, MO, TU, WE, TH, FR, SA, and D
for Special Day (usually a holiday).
-Press HOUR key to set hour {check AM/PM} you want program1 to turn ON.
-Press MIN key to set minutes you want program1 to turn ON.
-Press ON/OFF button to select ON, and then program1 will turn ON at your set schedule.
Press ENTER to confirm setting.
Display now shows --:-- 02 which is Program2
-Press DAY/MONTH key to set day(s) you want program2 to turn OFF
Choose same days you chose for Program1 ON so timer does not have conflicting programs.
-Press HOUR key to set hour {check AM/PM} you want program2 to turn OFF
-Press MIN key to set minutes you want program2 to turn OFF
-Press ON/OFF button to select OFF, and then program2 will turn OFF at your set schedule.
Continue setting up to 32 different programs.
When finished programming, press MODE button until RUN appears
Manual shows more programming options such as override, reviewing programs, setting special days.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
On timer light is flashing.and tv shuts off in about 5 seconds after turnig it on.
Hello
Timer function is in ON position and have been set to the least time I thinks. You just go to the menu and put the timer fuction of OFF.
The On/Off timer lets you program your television to turn itself on or off. You can use it as an alarm
to wake up, to help you remember important programs, or as a decoy when you're not home.
Press the MENU button
Press UP or DOWN button on the remote control hanset to ON/OFF TIMER
Make it OFF.
Switch off the TV by its front panel power button, and switch it ON again after 10 seconds.
OK.
3helpful
2answers
I bought a house with a Night Sentry Solid State Timer model # EJ341 and have no instructions on setting or programming the unit.
rapid Programming.
1. Move control lever to OFFCLEAR for at least 5 seconds
• red indicator light goes off
• all time settings are
erased.
2. Move control lever to ON.
• red indicator light will start
flashing.
3. Check a clock; then turn pushbutton time dial clockwise at least one click.
• stop at the half hour nearest to present time (note
AM or PM).
Note: When turning pushbutton time dial, do NOT
accidentally PRESS at the same time.
4. Press pushbutton time dial once to enter present time.
• red indicator light goes off (present time has been
recorded).
5. Turn pushbutton time dial clockwise to desired
ON time.
• red indicator light blinks with each click.
6. Press pushbutton to enter ON time.
• controlled light(s) will turn on.
7. Turn pushbutton time dial clockwise to desired
OFF time.
8. Press pushbutton time dial to enter OFF time.
• controlled light(s) turn off.
9. Repeat 5-8 for other on/off times.
10.Turn pushbutton time dial for at least 2 more turns
from the first ON time to complete this program
• red indicator light will turn on and stay on (steady
light means timer is in automatic).
Note: Pushbutton time dial does not turn
automatically after setting to indicate time of day
32helpful
5answers
I have a utilitech 0192773 self adjusting timer that will not program. Only works with manual on / off switch. How do you adjust to dusk to dawn
Do not go to Utilitech.com; it's a different company. It's actually at place called TheNCC and is in tiny, tiny print at the bottom of the instructions.
Instead, go to:
http://thencc.com/ncc/support_results.asp?criteria=192773&Submit=Go&SearchRun=RunGo
You should find a PDF for the product and then zoom in to be able to read the instructions. I was not able to read instructions that came in packaging.
2answers
TV turns off and the standing timer light blinks.
There is a timer option programmed into your set. Check the timer setting in menu, under advanced settings
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
