Lexmark X4270 All-In-One InkJet Printer Logo
Posted on Aug 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a printer cartridge ( black cartridge ) that was half full when shown. When I went to print paperwork, the cartridge displayed there was no ink in the cartridge. Also read Black Cartridge missing. The cartridge was in place don't understand why it is saying black cartridge missing?
Abhinandan Patil
Level 3:
Master:
  • Master 589 Answers
  • Posted on Aug 14, 2011
Abhinandan  Patil
Master
Level 3:
Master:
Answers
589
Questions
Helped
124229
Points
1347
There is a chance of cartridge been damaged either because of refilling or by any other reason try changing the cartridge
Printer tells me black cartridge is missing
Please remove your printer and uninstall the software from the PC. then reinstall the software and tehn connect back your printer to be detected and installed once again. I hope you have the software of the printer which came along with the set. This must get your printer back to action. I hope this helps . Good day
3helpful
I had an almost full black cartridge in my ESP-3 and it stopped printing any black. I put a brand new cartridge in and it printed for half a page and then stopped. I went out and purchased another and it...
clean the sensor pads on the cartridge and also on the printer as these can be causing the malfunction .
It pays some times to run a magnet on the cartridge terminals prior to use and during the malfunction as it reset the sensors
Dell 968 aio printer won't print black
I replaced the ink cartridges even though the levels still said they were half full. It worked perfectly.
Magicolor 2400w color low. how to allow printing in black without need to replace the color toner? I mean, i only need to print in black only so at the moment i can ignore the color low warning.
its not possible as whast u required.because all the cartridges should be shown full for printing whether you use the colour or dont use.
but you can get your cartridges refilled at any local stationery shop or at the local refilling center.
and this will not cost u as new cartridges.its exactly less then half cost of new cartridges.
thanks.
3answers
Printer will not print black ink
Hi please try these steps:::
Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (1), it is properly removed.
    *BCI-3's shown in this example.
  3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  4. Make sure each ink tank is snapped into the printer.
    IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
2answers
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
1helpful
2answers
Dissapearing yellow
I run about 100+ canon printers from s800 up to the new ip4500.
I have met and solved almost every problem I find described on the web. Your problem with the disappearing yellow ink can be only one thing. The ink cartridge has not been sealed after you injected the ink. If there is even the smallest avenue for air to get into the cartridge it will allow the ink to flow very rapidly back out of the cartridge and into the waste ink pads in the bottom of the printer. You won't be able to see a puddle of ink under the printer until much later when you have done many cleanings or installed many leaky cartridges.
3answers
Lexmark black cartridge-and printer x1270 not printing black
I have a lexmark 6570 with similar problem. Who can help?
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
