SOURCE: Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
SOURCE: My Maytag PAV2300AWW Performa is noisy on spin cycle
If you are talking about a loud sqeaking noise, this is usually attributed to a worn snubber ring and/or brake assembly. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is to get rid of most noise related problems (this will be the bottom round plate where it meets the casing of the machine). However, if the snubber is worn too much, or if the brake assembly is worn they must be replaced. I would recommend replacing the following parts:
Brake Stator: 1057484 Price: $7.45
Brake Rotor and Lining: 1032674 Price: $16.70
Snubber: 1055142 Price: $4.35
Brake Removal Kit: 997909 Price: $99.40*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself.
You can find all your parts and information at repairclinic.com. I am not affiliated with the website. I am merely recommending them because I have used their service before. Plus, they use the same repair parts as your major appliance repair companies, but at a lower cost.
The parts required to make the repairs aren't very expensive, but the tool required to do it IS. Also, if you've never worked on this type of washer before, this is not a job that I would recommended to the average do-it-yourselfer. Maytag is real good abpout providing the necessary instructions with their parts, but this is a bit involved.
Post back with comments and let me know if this helps you.
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact can you hear it click?If its not clicking or the arm is broken off the lid replace the lid switch/or the broken lid switch arm.
SOURCE: maytag performa PAV2300AWW will not spin but sounds like it is.
I think you have guessed it right. There is probably something stuck between the tubs. I have seen this caused by a lot of things. You should look for things as small as coins, shirt buttons, cufflinks etc., Also I advice you not to turn on the machine until the blockage is removed.
Good Luck,
Sai.
