First check that you have voltage at the outlet and that the switch is working. There is a reset button on the bottom of the unit - have you tried to reset that? If not, try it! If that doesn't do it, unplug your unit and use an allen wrench to rotate the motor (CW), if it won't turn then you either have something like a bone or spoon wedged in it or the motor is bad. If the motot is bad it is cheaper to replace than to repair.
