Iomega HDD External Desktop (32660) 80 GB Hard Drive Logo
Posted on Aug 14, 2011
Format Error occurred at offset 999,938,785,280 (19)
Error u60
code u60: Job offset home position sensor does not detect home position for the Job Offset Assembly.
check
home possition sensor actuator
home posiition sensor
sns harness ... is there any damage or misalignment. replace broken parts.
if that did not help
Test the job offset home position sensor.
run the service diagnostics offset home position test.
Does the sensor function correctly?
If yes you well have to replace the engine control board. That will give you that error. Hope this helps if you need more help let us know at iteminconline.
iteminconline
While it's plugged in to PC in the PC start session dos screen appear and saying S.M.A.R.T. error. I formatted(Write Zero) device with WD Diagnostic Tool(9 Hour) in DOS and HDD Low Level Format Tool 4.30...
after inserting the disk just click on eror .
click on fix errors .
if this does not works its a physical damage.you can save it first and then run it as soon as you insert the disk
My toshiba hard drive is locked and i can't unlock it ?
Try using MHDD v4.6. It included in Hiren's Boot CD. You may have to write a script though, if you can figure out how.
NW-E003F and i am having FORMAT ERROR
The FORMAT ERROR message may occur if the Walkman player has been formatted using the format utility in Windows Explorer. To correct this issue, initialize (format) the portable player using the Initialize or Format utility built into your Walkman player.
Home button-->Menu-->Advanced Menu-->Initialize-->Format-->OK.
Reset the unit by pressing the RESET button with a small object such as a paper clip. Reset button is located near the volume buttons.
If the issue occurs after making any changes in the SonicStage Software, then reinstall the Software in the Computer using the latest version. Click here to download the latest version of the SonicStage Software.
This should resolve the issue.
Thanks for using FixYa
While running diagnostics am getting an error code 2000- 0111 in my inspiron 15R laptop
If you receive an error during PSA Diagnostics, look below for the associating error code. If the Error
Error Code
Error Message
Link to Possible Fix
PSA 1000-0111
PSA+ 2000-0111
(Name of Exception) exception occurred at selector XXh offset XXh.
Contact Dell
Kingston 2 gb i cant format showing insert a disk and then try again i want format how
sir if you are using adaptor of memory card for connect it with pc then i think this error occurs so use card reader and then insert the memory card in it..........the right click on the removal disk and click format when you click on format then click quick format then o.k if this error occurs again then scan the device or go to device manager and then check whether the property of usb is enable or disable if error still continue then mail me at [email protected] i will help you again take care
1helpful
3answers
More than 256 characters in a cell in Excel
If a RANGES
\r\n
Named Ranges. SheetLevel Named Range, Named Constants, Named Formulas ,Relative Named Ranges ,Dynamic Named Ranges ,Advanced Dynamic Named Ranges .
\r\nWorking With Ranges. FindLast cell/row/column etc.
\r\nFormula Reference Changer. Absolute to Relative etc.
\r\nSpecialCells Method
\r\nExcel Named Range Manager $
\r\nOFFSET RANGES VBA
\r\nReturns a Range object that represents a range that?s offset from the specified range. Read-only.
\r\nexpression.Offset(RowOffset, ColumnOffset)
\r\n\\"expression\\" is required and should be a Range object.
\r\n
\r\nRowOffset: Optional Variant. The number of rows (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset downward, and negative values are offset upward. The default value is 0.
\r\n
\r\nColumnOffset: Optional Variant. The number of columns (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset to the right, and negative values are offset to the left. The default value is 0.
\r\n
\r\nExample
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(RowOffset:=-1, ColumnOffset:=2).Address
\r\nEnd Sub
\r\nIs the SAME as;
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(-1,2).Address
\r\nEnd Sub
\r\nOFFSET FORMULA
\r\nReturns a reference to a range that is a specified number of rows and columns from a cell or range of cells. The reference that is returned can be a single cell or a range of cells. You can specify the number of rows and the number of columns to be returned.Syntax = OFFSET(reference,rows,cols,height,width)
\r\n
\r\nExamples
\r\n=OFFSET(C3,2,3,1,1) Displays the value in cell F5.
\r\n=OFFSET(C3:E5,0,-3,3,3) Returns an error, because the reference is not valid.\", \"style=\\"background: #FFFFFF;padding: 2px;font-size: 10px;width: 550px;\\"\");" style="FONT-STYLE: italic" onmouseout="GAL_hidepopup();" href="http://www.ozgrid.com/forum/autolink.php?id=5&script=showthread&forumid=8">cell is formatted as Text, then it will display the #### when the text is over the limit. Reformat the cell to General and the text should again show.
Right click on the cell, click Format Cells, under the number tab, choose General.
Also, this ####, will occur is the cell width is to small.
Top Iomega Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Jerry Naidoo
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
