SE is actually 5E and means that the water has not pumped out of the machine in the time period allowed. It can be caused by a blockage so check the pump by taking off the black cover at the bottom right hand side on the front of the machine, be aware that if there is still water in the machine this will let it all over the floor. There should be a smaller white plug, twist this and pull and a small hose will come out to allow you to (slowly) drain the water.
SOURCE: Error code SE or 5E
'SE' is a temporary sensor error. Switch off power at wall plug, wait a few seconds, switch it back on and it may clear the fault.
SOURCE: Hi I've got Washing Machine LG
the alarm is indicating that the machine is not working that u should restart it or better still u check the mabual for p[roper operation
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
