If your sound is not working after installing then it means your sound driver is not installed properly.
So you need to either re-install XP or download the drivers.
Anyways i will give sound card driver to be downloaded.If you re-install XP again then make sure that your speaker is ON !
Here is the download link below.After installing kindly restart.
http://xpdrivers.com/sound-audio/_1_23.cfm
I hope it helps.
Thanks
This is fairly normal with fresh installations of Windows XP especially if your computer utilizes sound card and other components that Windows does not have "native" drivers for. You will need to install chipset & audio drivers directly from your computer/motherboard's drivers disc (in some cases, network and video drivers will also have to be re-installed, but they should also be in that disc).
If you no longer have that disc, then you'll have to find out what make and model your computer/motherboard is so you can download the drivers directly from the manufacturer's website. These drivers and their corresponding applications are free to download.
Hopefully you still have the disc so you would not have to locate the brand and model, etc.
