I have 5 Direct TV receivers. Two are HD while the others are standard receivers. Certain channels get weak during slight weather conditions, pixelate, and say "searching for signal". However, these occasionally weakened channels are only on the two HD receivers. The 3 standard receivers always look great. So, the problem is only with the HD side of things. It would be my guess that the HD LNB could be bad or does the dish need to be aligned better so as to "look" at the other satellite better? I've checked the connections on the multiswitch.
Television system: NTSC-M
TV Standard
Closed Caption
System: §15.119/FCC
Channel coverage
VHF: 2 - 13
UHF: 14 - 69
CATV: 2 - 13, A - W,
W+1 - W+84,
A-5 - A-1, 5A
Tuning System: 181 channel
frequency synthesized
tuning system
Channel access: Direct access keyboard,
programmable
scan and up/down
Terminals
Antenna input: VHF/UHF/CATV
75 ohm unbalanced
(F-type)
Video input: RCA connector x 1
(1 x Front)
Audio input: RCA connector x 1
(1 x Front)
1 speaker
ELECTRICAL SPECIFICATIONS
Sound output: 1W, 8 ohm x 1
OTHER SPECIFICATIONS
Remote control: Digital encoded
infrared light system
Operating
temperature: 5°C to 40°C
(41°F - 104°F)
Power requirements: AC120V, 60Hz
Power consumption
(Maximum): 98W
Picture tube: 23"
Dimensions: H : 20-3/8" (518mm)
W: 22-13/16" (580mm)
D : 18-7/16" (469mm)
Weight: 55.1lbs. (25kg)
•Designs and specifications are subject to
change without notice and without our
legal obligation.
•If there is a discrepancy between languages,
