The Nikon D-90 manual addresses this problem on Page 256.
It says that ERR indicates a camera malfunction and can be cleared by releasing the shutter.
I usually have to turn the camera off and back on to do this.
Sometimes, I have to remove and reinstall the battery.
The manual also says that if the problem persists to contact a Nikon authorized service center. Before doing that I suggest you contact Nikon tech support at www.nikon.com and see what they have to say about the problem.
Nikon Imaging Products Support Page: http://imaging.nikon.com/products/imaging/support/index.htm
Click here for repair information.
Hope this helps; also keep in mind that your feedback is important and
I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
SOURCE: err on the lcd of nikon d70
Most digital equipment has some kind of manual reset. Refer to your camera manual to see if there is a sequence of buttons that will reset to the factory settings.
I had a similar problem with my Nikon D200.
I resolved it by setting the camera to manual mode (any aperture and any shutter speed) and firing the shutter release. Manual deactivates almost all other functions and may clear the error.
Try another battery, memory card, lens to eliminate all possibilities.
Have you looked to see if the mirror is locked up revealing the sensor at the back of the camera body?
SOURCE: purchased the D90 with 18-105 kit lens yesterday.
According to and directly from Nikon:
When you see Err on the control panel, LCD monitor or viewfinder of your digital camera it refers to a camera malfunction. Try the following:
If these steps do not resolve the Err message we recommend having a
Nikon Authorized Repair Technician evaluate the Nikon camera. Click here for repair information.
SOURCE: Nikon D90 ERR message after taking picture -
I have the same problem like you. I take 3 photos with my Nikon D80 and this message came out : ERR ... I have NO idea what should I do ? ! Please help me... Lucas
SOURCE: nikon d90 stops working after drop on
you have see first visible damage. However camera should be dropped. D90 is not magnesium case.
SOURCE: nikon d80 will not take pics has err flashing in
Hello
The problem is that the lens has become stuck in the barrel
after dropping it. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful.
Regards
Andrea
