Question about Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15
Live in florida - pool pump goes off for a half hour and then turns back on and then operates normally for a while. it then repeats the same eequence. is this due to overheating
  • 366 Answers
It does sound like overheating. runs for a while, trips the high limit, then cools and restarts. this could be a supply power problem, under sized wiring, or loose or damaged terminals associated with the wiring.
Posted on Aug 14, 2011
Testimonial: "Thanks for the quick response. I'll try all your suggestions. JC"
6ya staff
SOURCE:
When pump is on Bypass, water comes out strong through both inlet jets into the pool, but if pump is on normal (Filter), nothing comes out at the 2 jets. Water in the pump basket even drops somewhat.
could be clogged line take lid off pump have someone with garden hose shoot water back up the jet to see, or it could be a valve is set in the wrong position, it always nice to have two people for this job.
Jay the pool pump repair guy in longwood Florida.
Mar 07, 2018 | Pool & Spa
Pump on my Intex air mattress shuts off before the bed is inflated
Pump is ng and needs replacement. Take it back if under warranty.
May 03, 2017 | Intex Pool & Spa
Nitro pool cleaner
sounds like the motor is overheating
Oct 10, 2013 | Pool & Spa
Replace pool pump impeller
NO, should have just a little resistance, you might have a hayward and the o-ring sticks to the impeller shaft and must be removed. OR you have the rotor bearings installed wrong, this too will cause improper shaft clearance.. should be a easy fix. good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
Aug 09, 2013 | Pool & Spa
Hurlcon cx240
bad sensor and cell calsified need to super shock poool
Mar 19, 2017 | Pool & Spa
Pressure goes up after 2 hours
JUST KEEP CLEANING IT IT TAKES TIME TO GET ALL OF THAT WATER CLEAN !! OR IF THE ELEMENT IS OLD IT MIGHT NEED REPLACEMENT
..JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXYA GUY
May 08, 2012 | Hayward EC-40 DE Pool Filter with pump
I need the wiring diagram for the point contacts on the back of a dura-glas 1 1/2 hp pool pump. thanks
7_26_2011_8_21_59_pm.jpg2 YELLOW GO ON 1 POST ON CAPACITOR , THE ONE RED GOES TO THE ONE SIDE OF THE POINTS THE RED/WHIT GOES TO THE POINTS AND TO THE OPEN LUG ON THE CAPACITOR .. SORRY ABOUT THE PICTURE , THE OTHER ONE WOULD NOT LOAD .. JAY THE POOL PUMP MOTOR REPAIR GUY LONGWOOD FLORIDA .
Jul 25, 2011 | Sta Rite Sta - Rite 1hp Dura - Glas...
Not self priming itself. when it turns off the water pushes back out of the skimmer and pushes the basket up. it loses water and the pump cant re-prime itself.
PRIME PUMP, OPEN AIR VALVE ON FILTER. OR TAKE THE LID OFF YOUR FILTER AND SEE IF IT STARTS TO PUMP... YOU DO HAVE IT PLUMBED RIGHT? THE PIPE COMING OUT OF THE PUMP GOES TO THE FILTER !! I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Aug 28, 2010 | Waterway Inground Pool Pump Champion No....
My pool is green. why.and how do I fix it
according to your picture I see you are running the satand alone salt unit..
If you are running an intex filter/pump you are probably not getting enough filtration.
A pool turns green for many reasons such as not enough use to stir up the water
Not enough filtration
wrong levels of chemicals and so on
My suggestion
Start by testing your salt it needs to be as close to 3000ppm as possible
now shock your pool with either liquid chlorine or a substrate for your amount of gallons in the pool
After 24 hours of shocking brush your pool with a seperate pool brush sides and bottom
Do not depend on a pools vaccum with bristles you can not get enough elbow grease going to make it work well
now that it is brushed wait 24 hours and then vaccum.
Do this until the water clears
You also need to blow out the filter cartridge at least 3 times a day so that it cleans efficiently
once your pool starts to clear up again make sure your salt is 3000ppm
now make sure your ph is close to 7.6
and make sure you put a stabilizer in to help hold your chlorine level longer
I do not know what gallon your pool is so I will just use generic #'s to discribe what a pool needs
A pool need to be turned over at LEAST 3 times in a filter cycle so if you have a 2500gl ph pump and your pool is 5000 that is 6 hours of filtering alone
When you are generating salt you should count the 6 hours as half the intex units do not filter well while generating chlorine. you may be told differently by intex but I have had my set up for 3 seasons and have found what works for me
an intex pump draws as much electric as about a 40 watt light bulb
so I run mine 24/7
I generat my chlorine at the end of the day any where from 3 -7 hours depending on # of bathers,sun,heat, suntan oils and so on then I filter the rest of the time I also clean out my cartridge every day.
It is best to have 2 filters one in the pump and one drying. I do not know why but a wet filter after cleaning does not filter as good as a filter that has been clean and dried
Again for your problem now shock filter brush and repeat ti'll it clears up
Once a pool goes green it is a lot of work to get it back on track
hope this helps
Jun 19, 2010 | Intex Automatic Salt Water System for ...
Lost manual
I am assuming you have poured in the correct amount of salt. If not post the size of the pool and I can list the correct amount. Now, you will need to set the hours of operation according to the size of the pool which I need to know in order to help more. I will go through the procedure of startup. When you turn the pump on after dissolving the salt in the pool, it will show a code 88 which is normal. Press and hold the down button for 2 seconds until you hear a short beep. The LED will flash 00. Your keypad is now unlocked. Push the up button to set the number of daily hours of operation according to the size of your pool. Up to add hours, down to remove an hour. If you do not have an owner's manual tell me the size and where you live and I can tell you how much salt to add and hours each day to run.
May 30, 2010 | Intex Automatic Salt Water System for ...
Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Logo
270 people viewed this question
Top Hayward Pool & Spa Experts
Bill Jordan
john h
US Parts Center
US Parts Center
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
