My PhotoMAX software gives a "Connection failed" error message when I try to download images from my digital camera to my computer using a USB connection.
The "Connection failed" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily identified: * Make sure that the computer's operating system is USB compatible. Microsoft Windows 95 and NT operating systems are not compatible with USB technology. (In addition, PhotoMAX and PhotoImpression software cannot be installed on Windows NT systems.) If you have an incompatible operating system, you must upgrade to Windows 98, Me or 2000 to use a USB connection. Your computer must also have the appropriate USB connectors. NOTE: This camera cannot make a USB connection with a computer running Windows XP. * Make sure that the camera power is on. Follow the camera instructions to turn the camera on. Some cameras conserve battery power by turning off automatically after a few minutes of inactivity. If necessary, install new batteries or connect the camera to AC power (if it has an AC power adapter). * Make sure that the camera is correctly set to access images. Make sure the camera is turned on and that its mode dial (if it has one) is correctly set for transferring pictures to the computer. Refer to the camera user guide for more information. * Make sure that the camera cable has not been damaged or become disconnected from the computer. Confirm that both of the connectors are firmly attached. Check the cable for breaks, kinks or other defects, and check the connectors for bent or broken pins. If the cable is broken or kinked, obtain a new cable.
SOURCE: "Camera not connected" -- USB connection
The "Camera not connected" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily identified: * Make sure that the computer's operating system is USB compatible. Microsoft Windows 95 and NT operating systems are not compatible with USB technology. (In addition, PhotoMAX and PhotoImpression software cannot be installed on Windows NT systems.) If you have an incompatible operating system, you must upgrade to Windows 98, Me, 2000 or XP to use a USB connection. Your computer must also have the appropriate USB connectors. * Make sure that the camera power is on. Follow the camera instructions to turn the camera on. Some cameras conserve battery power by turning off automatically after a few minutes of inactivity. If necessary, install new batteries or connect the camera to AC power (if it has an AC power adapter). * Make sure that the camera is correctly set to access images. Make sure the camera is turned on and that its mode dial (if it has one) is correctly set for transferring pictures to the computer. Refer to the camera user guide for more information. * Make sure that the camera cable has not been damaged or become disconnected from the computer. Confirm that both of the connectors are firmly attached. Check the cable for breaks, kinks or other defects, and check the connectors for bent or broken pins. If the cable is broken or kinked, obtain a new cable.
SOURCE: "Connection failed." -- Serial connection
The "Connection failed" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
SOURCE: "No camera is connected" -- USB connection
The "No camera is connected" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
