SOURCE: forwarding a call
Lift handset, dial 3 or 6 ( depending on model) - key outside line access code - key phone number (eg mobile)- key # - hang up
SOURCE: Call Customer Service 1-8O5-465-751O To Fix Issue Outside Line Button.
I doubt you would be looking to "delete" the number. Instead you need to program that button to be a line button again and that will in effect delete the quick-dial you programmed. I'm not sure which phone system you have your phone connected to (you could have one of several different Panasonic systems) but programming the button for a line should be somewhat similar to programming it for speed-dial.
Does the manual you have cover any other programming options for buttons?
It's a long shot but some systems I am familiar with you can just push the same button again instead of the number. So for example if this was the line3 button, program similarly as you did before but at the step where you dialed the number, just press the line3 button.
If you're still stuck, let me know which Panasonic phone systm you have so I can look up more detail (the system is not a phone)
SOURCE: CALL FORWARD
hi prabipm,
just follow this instruction.
1.lift hand set or press sp-phone
2.press fwd/dnd botton
3.press 0 and # sign
hope this help...
SOURCE: Speed Dialing KX-T7453
Part of the number you store in your speed dial has to include a "9" or 8x access code to get an outside line.
Carl
SOURCE: PBX: KX-TA624 PHONE:KX-7730b. need to forward call to outside lin
Sorry that We were disconnected from our chat session.
Here is the manual guide explained with steps for forwardign ur call:
http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
Check out the "Page 6" in this manual
Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
