Expert
- Posted on Aug 13, 2011
Re: When I turn the oven on it starts to warm but shortly...
Sounds like an error code. your oven ignitor may have gone bad. thats what tells your oven to send gas or power to the oven and turns it on... have that checked. i hope this helps
Hello, Would you happen to know the make and the model number of the unit? With the model number I am able to give a more specific solution and there are also many different ovens with many different reasons for each on the EO error code. Did you also happen to see an F code as well either before or after the EO error code. Also try unplugging the unit for 7 minutes this usually allows the control to be able to reset. And message me back with your results after you unplug or turn off the electrical breaker on the unit. I await your reply Thanks Rick
