No Fuse However this model is known for having the switch go bad. You can check it with a meter or Continunity tester with the unit unplugged
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
I had the same problem, It was the switch. I shot it with WD and did not have to replace the switch.
i got frustrated. i didnt have any WD40 so i hit the switch with a hammer. and it started working. go figure! really. that's what i did. no joke.
I had a hammer and WD. Hammer didn't work but the WD did! Thanks for the tip!
You guys sprayed the "On/Off" switch with WD40 and it worked?
You guys just sprayed the "On/Off" switch with WD40 and it worked? Or is there some other switch im not seeing?
