Question about Whirlpool Ovens
How do you recalibrate the oven temperature of a Whirlpool Accubake oven system
  • 2,341 Answers
To do that;
  1. Press BAKE
  2. Select a temperature of 550 or highest temp on some models its 500
  3. Quickly (within 5-seconds of setting 550) press and hold the BAKE button approximately 5-15 seconds until "00" or the previously entered temperature adjustment is displayed.
    Pressing longer could cause an F0, F1 or F7 error to be displayed.
  4. Press the UP/DOWN arrow button or turn the set knob to change the oven temperature in 5° increments to a maximum of +/- 35°
  5. Press the CLEAR or OFF button to return to normal operation.
Gene
Posted on Aug 12, 2011
6ya staff
SOURCE:
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Whirlpool Accubake Wall oven pre heat but temp goes 350 and downwards when pressing temp up
I am not sure about this, but sounds like a connector is on backwards or in the wrong place.
Nov 26, 2014 | Whirlpool Ovens
Whirlpool oven keeps heading up
What is the model number of your unit?
Jun 26, 2013 | Ovens
Oven door will not open
This unit may have a door lock built in to the control unit lockout. To release it you may have to turn off the oven circuit breaker in your house circuit box. If not, it is just jammed and you will need to wobble it free.
Jan 12, 2013 | Whirlpool RBD275PVS 27" Double Electric...
How do I change the temp fro m degrees C to degrees F? I have a Accubake System single oven. Thanks!
From Page 15 of the Manual:
Press and hold the "Custom Broil" pad for 5
seconds. A short tone will sound
NOTE: The temperature display will go off
and the temperatures displayed will
after a conversion. The temperature display
be converted. To switch back to "F, repeat the instructions above.
NOTE: The temperature display will go off after a conversion.The temperature display will reappear the next time you press a cook function command pad.
Jul 16, 2011 | Whirlpool RBS275PD Electric Single Oven
Started the clean cycle but remembered that I wanted to remove the oven racks and quickly tried to turn off the oven but the door had already locked - now I can't get it to unlock - what happened? This is...
It can take 4 hours to complete. I also see that many people have problems with the temperature sensor "Blowing" after they use that function. When you do the clean special door interlocks activate and the oven heats up to like 900 degrees!
Feb 18, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool accubake oven (elec) E-2 F-3 fan running oven wont't heat all other functions normal
Hi, your oven will not heat if the temp sensor is faulty or damaged. this code represents a non-responsive oven temp sensor.
Replace Oven temperature sensor (RTD)
Aug 15, 2009 | Ovens
Whirlpool Accubake Duo Oven Not Heating up
the oven not heating up. it's start up some time and other time u just hear it try to click on but don't hear no fire turn on
Jun 15, 2008 | Ovens
Ovens Logo
374 people viewed this question
Top Whirlpool Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
