The secod race is a DRAG in Harbour & Ocean.
1. Second event is a Drag race, which will require you to push additional button to shift gear up or down "check your controls for configuration" to avoid blown engine sticking on gear 1. as you can see while accelerating the speedometer rises before it reaches the red boundary shift gears up to avoid blown engine.
Another simple race. Be sure to avoid the truck that'll appear on your left (#1). You won't have much time to make a correct manoeuvre. Be sure to change lanes often. use Mitsubishi Lancer EVO VIII its handling is good on tight corners an also fast.
Hopefully this information helps.
Thank you for using FixYa.
