Computers & Internet Logo
Posted on Aug 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can zoom in or out when in full page mode anymore, just started yesterday aug 10/11
Anonymous
Level 2:
Novelist:
  • Expert 182 Answers
  • Posted on Aug 12, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
182
Questions
Helped
33348
Points
461
There is a pretty obvious bug when using 'Marquee Zoom' (Alt+5) in the full screen mode (F11). When you press 'Ctrl' to toggle 'Zoom In' and 'Zoom Out' (changing the little magnifying glass cursor from + to - and back again), it sticks with 'Zoom Out' and refuses to toggle back to 'Zoom In'. And then the only way to recover 'Zoom In' is to exit full screen mode, whereupon 'Ctrl' regains its toggling power and everything is back to normal
1helpful
In Chile just bought a camera Lumix DMC FZ70, zooming only works in automatic mode AI in the other modes only works zoom 1 to 3x, please indicate what should I do
Zoom 1x to 3x sounds like the limits of optical zoom. The other zoom option may be digital zoom, which merely interpolates pixels to give the impression of a larger picture, and, as you reach the limit of the zoom, the picture quality may be so degraded that the image is unusable.
Screen seems stretched. How do I fix it?
60'' Vizio TV screen is stretched in 'normal' screen mode on HD ...
https://answers.yahoo.com/question/index?qid...
Jul 21, 2013 - Ive had this tv for almost a year and the screen has never given me problems, but just recently all the HD channels are stretched. ... If your Vizio is like my 47" it has 4 Picture Modes - Wide, Normal, Zoom and Panoramic. ... Why isnt my viziotv able to play full screen hd channels?
TV Problem: The picture on my television is stretched out on the ...
Aug 23, 2008 - It is a High Definition Vizio TV. The center of the screen is clear, but the television stretches the image out on the sides. Is there anyway to fix ...
How to Fix the Most Annoying Features of Your New HDTV ...
Google search
Try zooming your the Safari window (click the green button at the top left of the window's frame) or try putting Safari into full-screen mode (click arrow thingy at top right of window frame) to see if the text box reappears. You can switch in and out of full-screen mode by typing control-command-F.
If this doesn't do the trick, navigate to a SPECIFIC page in Google search (start at www.google.com), then open Safari Preferences, click the General tab, and click the "Set to current page" button.
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
4helpful
2answers
How do you format card on olympus c-310
Select MODE MENU, CARD, CARD SETUP, then press cursor-right.
Full details are in the "CARD SETUP - Formatting cards" section starting on page 91 of the manual.
6helpful
My olympus c765 beeps when the shutter closes. how can it be silenced
In the top menu, select MODE. Select MENU, SETUP, the box-with-sound-waves icon, then OFF. For full details see "Beep" on page 152 of the Reference Manual.
Dragon voice stopped working yesterday-suggestions?
hello, I also meet this error about my iphone, I get many help from this forum, and also bought many DIY repair tools from china supplier, and vipprogrammer help me fix this error. maybe you can try it. or contact they WhatsApp:+ 8615986801289
Link: http://www.vipprogrammer.com.
hope can help you!
The menu in my canon sx10 is camera where the digital zoom is located is not "illuminated" as a menu selection I can pick to turn the digital zoom back on. If I try to pick it from the menu, it...
There are certain modes that you simply can't get digital zoom in (such as widescreen mode). If that isn't the problem, perhaps it's not enabled. According to the manual which I believe is here: http://gdlp01.c-wss.com/gds/7/0300001567/01/PSSX10IS_CUG_EN.pdf on page 54 of the manual (p56 of the PDF) it shows that the digital zoom can be enabled in the FUNC menu (in a record mode). The description of digital zoom, including the safety zone, which might explain why you can't get digital zoom under certain circumstances, is on page 68. Note that there's a big chart on page 286/287 that shows what features are available in each mode - I have a feeling that this could be your problem.
3helpful
Cannot sign into Yahoo mail since Aug 26, 2009
I just logged into my yahoo mail account, the server is not down. They made some changes to the restore password procedure. You need to enter your user email address and password again and then a page will come up where you have to configure 2 security questions and answers. After entering this information you will be directed to your mailbox.
Success
Aug 27, 2009 • Yahoo Mail
Grand Canyon Tech
Grand Canyon Tech
