SOURCE: Konica Minolta Dynax 5D/Maxxum 5D turns itself off after first shoot
It sounds like that's the first black frame problem that is a fairly common defect with the cameras, so much so that Sony is repairing it for free, for more info, see:
http://ca.konicaminolta.com/information/20070202/01_en.html
then go to:
http://eservice.sony.com/webrma/web/index.do to set up for service.
SOURCE: Bracketing in Maxxum 5D
Hey arnelsartwor,
To set both exposure and flash bracketing you need to press the drive mode button, and then use the up/down arrows to select bracketing and then use the right/left arrows to highlight the drive mode option and then press the center button to select the desired drive mode. These instructions are on page 50 of your user manual. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: Minolta Maxxum 5D
The P-channel MOSFET switching the CF power is dead. It is on the little board directly above the battery compartment. SOT23 package, the marking is 338 or something like that. Replace it and it will work.
SOURCE: My Dynax 5D will not release the shutter nor will
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
SOURCE: need to set self timer
Press the MENU button, select "Drive Mode," then select the self-timer (one-handed clock). To start the self-timer, press the shutter release button.
