Adjust the position of the door by using the black and purple
buttons. Black moves the door UP (open) and purple moves
the door DOWN (close)
Setting the up position:
1. Press and hold the black button until the LED starts flashing
slowly, then release.
2. Push and hold the black button until the door reaches the
desired UP (open) position
3. Push the door control or programmed remote control. This
sets the Up (open) position and begins closing the door.
4. Immediately when the door begins to close press and release
the black or purple button. This will stop the door
Setting the Down position:
5. Push and hold the purple button until the door reaches the
desired DOWN (Closed) position.
6. Once the door is closed, If there appears to be too much
pressure on the door, you may toggle the door back and forth
using the black and purple buttons to reach the desired closed
position.
7. Push the door control or programmed remote control. This
sets the Down (closed) limit and the door should open.
