If there is a connection for the SATA drive, the bios should see it. You'll have to go into the bios setup (hit F2 key repeatedly on reboot) and look around until you find the setting. I cannot tell you exactly where it is, as you may have a different bios version. I suggest you plug the drive cable into the "SATA 0)", plug in the drive power plug, and then hook up the main (110 volt) power cord. Don't forget the power for the new drive. I also suggest you try changing ONLY ONE SETTING AT A TIME. Write down where it was, how you got to it, what it was, and what you changed it to. If that does not work, it will be easy to undo what you did, and try another setting. Years of experience has taught me not to make wholesale changes to the bios. Look for something like "Integrated Peripherals"
SOURCE: IS HD161HJ COMPATABLE WITH MS-6741
Be sure that SATA is enabled in your BIOS settings. Sometimes if the computer ships with an IDE drive, the company that builds them will disable SATA in the BIOS. Also, while you are in your BIOS, if you decide to use just the SATA drive, you need to disable your IDE and set the bios up to boot the computer from your new drive on the SATA connector.
SOURCE: T6524 bios update needed
This isnt necessarily a bios problem mate , its just windows got corrupted during the power surge. Use the link below to do a repair install. Note , repair installs do not erase your personal files or setings or software !
http://michaelstevenstech.com/XPrepairinstall.htm#RI
Hope this helps you
If you found this solution helpful , please rate below
Kind Regards
1234s282
SOURCE: bios update for t5226
It isn't the fact of the BIOS, it's the motherboard chipset.
The eMachines T5226 uses an Intel 945G.
This chipset only supports processors with up to a 1066MHz FSB.
Supporting Data:
1) eMachines T5226 specifications;
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5226
2) List of Intel Chipsets, and more specifically the Pentium 4/Pentium D/Pentium EE chipsets,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_Chipsets
The Intel 945G is the 12th one down, or last in the list.
Looking across to the right, you can see the Intel processors supported, and the maximum FSB support.
(533/800/1066)
The motherboard's BIOS also won't let you overclock the FSB.
The Intel Core 2 8400 has a 1330MHz FSB,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Wolfdale.22_.2845_nm.29
The Intel 945G also won't support Intel processors with the Wolfdale Core.
