Please remove the both catridge and replace again... I think it may help you. thanks
I'm sorry. My english too poor. So i post by indonesian.
Sya juga sering mengalami error dgn kode B200 pd Canon Pixma MP 258 saya. Solusinya sangat mudah. Matikan saja printer trsbut, lalu cabut smw kabelnya. Setelah beberapa menit, pasang kembali. Insya Allah, printer siap digunakan.
SOURCE: does not print error b200
Helo, found on web. Good Luck :0)
The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864
SOURCE: Error Code B200
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
SOURCE: ip 5300 error b200 10 blink orange-green
SOURCE: error B200 on canon PIXMA iP3300
1.
Connect the USB cable directly to a USB port on the computer
2.
Connect the USB interface cable
3.
Delete the printer (MacOS X), and then add it back again
4.
Reset the printer
5.
Try a different data cable
6.
Verify proper driver installation in Mac OS X
I hope it helps!!!
