Several problems with this unit. 1st when hydro goes out (which happens fequently in our area) refridgerator does not start up again.- have replaced the main pcboard, and in the process of replacing transformer ( although output readings appear to be constant at 9.5 and13.5 volts. so far not able to find problem. 2nd now the refridgerator although showing a reading of 1 degree celsuis internal temperature is actually 12 degrees celsuis. is it possible to find a repair manual for this Item to fix these problems. unfortunately samsung's support page will only let you set up a service call with 1 company in my area and with past experience with them ( another samsung product) I am unwilling to deal with them.
SOURCE: RS21DGRS SAMSUNG SIDE BY SIDE REFRIDGERATOR
hi thanks for the question it might be a problem with a little frost on the freezer wall fridge not defrosting check the freezer wall with your hand,will feel some frost if this is the problem thanks the appliance doc you
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
SOURCE: My samsung refrigerator model RB1855SL is
Hey Luckydawg70, did you ever get the issue worked out? I'm experiencing the same thing with mine. I've been unplugging and replugging it in to keep it cold.
SOURCE: my Samsung RB1855SW refridgerator not cooling
You may just be catching the unit during normal defrost cycles. Next time, allow the unit some time to complete it's needed task. If you allow it 30-minutes, it should restart on it's own. The cycles are necessary to keep the unit working properly. The cycles will be more frequent as the weather warms. If you allow the unit 30-minutes and it does not restart on it's own, then there could be a problem. You might consult the owners manual for more details.
