Here is a direct link to the User's Manual for your model of GE phone:
http://www.home-electronics.net/ge/pc/IB/25952EE1_IB.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 2 of the manual for detailed instructions on how to program phone numbers into your phone's MEMORY.
I hope that was helpful to you, good luck and take care.
If you choose to rate this solution by clicking on the YES THIS WAS HELPFUL icon, I thank you very much for your time and consideration.
Joe.
Here is an excerp from that section of the user's manual:
Programming Phone Numbers Into Memory
Each handset can store up to ten 24-digit numbers with up to 15-character names in memory for quick dialing. This memory feature is in addition to the CID memory log, which stores up to 40 CID records in each handset.
Storing a Name and Number in Memory
1. Make sure the phone is OFF (not in TALK mode).
2. Press the mem button.
3. Press the desired memory location (0 through 9) or use CALLER ID-VOLUME (5or6) to scroll to the desired memory location.
NOTE: If the memory location is occupied, the memory location number and stored name and telephone number shows in the display. If the memory location is empty. EMPTY shows in the display.
4. Press the mem button again. The display shows ENTER NAME.
NOTE: If you don't want to enter the name, skip step 5.
5. Use the touch-tone pad on the handset to enter the name (up to 15 characters) and press the memory button to save. More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press the 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
NOTE: If you make a mistake press the chan/delete button to backspace and erase the wrong character(s) or number(s).
6. Press the mem button to save the name. The display shows ENTER TEL NUMBR.
7. Use the touch-tone pad to enter the telephone number you want to store (up to 24 digits).
NOTE: The system treats PAUSES as delays or spaces in the dialing sequence.
8. Press mem again to store the number. You will hear a confirmation tone.
